Cant export data
Discussion in 'Yoda - ForceFeedback Scanner' started by Duffy89, Mar 12, 2009.
  1. Duffy89
    Duffy89 New Member
    Hi all
    I am sitting here trying to get my data fro yoda exportet but when i right click om it and select export. It cant export the data. Any idea what the problem?
  2. egoexpress
    How many pc, which program version, which Yoda effect have you tried to export?
    Is the correct IP number is entered in Yoda?
    Is the network enabled in Yoda?
  3. Duffy89
    Duffy89 New Member
    I am sitting whit my laptop and havde indstallet Yoda 2 (the latest x-sim pack 1.6.9)
    And i am trying to export Magnitude effect.
    Havent enabled the network and havdet set any ip
  4. egoexpress
    Enable it!
    Btw, Yoda exports to the Force-Sender, so ensure Force-Sender is running as well.
  5. Duffy89
    Duffy89 New Member
    Have enabled network and have force sender running but still wont work
  6. egoexpress
    1.6.9 is the latest XSim1 version, so what's the point? Yoda should work in this version...
    @Duffy89
    Is Yoda activated in the Force-Sender settings tab as well?
