Can't install ponyprog in vista 64bit
Discussion in 'Miscellaneous' started by Jeroen, Feb 1, 2009.
  1. Jeroen
    Jeroen DoctorXeno
    Holland
    - 55Coins
    When I try to install ponyprog I get an error...
    This program can only be installed on versions of windows designed for the
    following processor architectures : x86
    I run vista ultimate x64.
    Is there another program that will run on x64 to program the amc1.5?
    gr. Jeroen
  2. tronicgr
    tronicgr
    Hi Jeroen,
    Download this version of ponyprog that I have put on rapidshare...
    http://rapidshare.com/files/192763805/PonyProg2000_207c.zip
    ...and unzip its contents in the following directory:
    C:\Program Files\PonyProg2000\
    Then create a shortcut of the PONYPROG2000.EXE on your desktop to find it easily.
    Regards, Thanos
  3. RaceRay
    23,862Coins
    is it a cracked version or something? Are we allowed to upload the programm in to the download section before the rapidshare link is broken?
    regards
    René
  4. tronicgr
    tronicgr
    No its not cracked version or anything... Its normal installation from my computer that is winxp.
    I just packed my installation directory to try to use it without installing it, since he mention he can't install in under vista64 ...!
    Why anything uploaded and shared through rapidshare must be illegal software only???? :lol:
    BTW, I own rapidshare premium account to keep my online files alive!! (video tutorials, HQ video of my sim, etc...)
    Thanos
  5. Deleted member 4120
    Deleted member 4120
    :( i cant flash atmega.. for thanos controller... (i have windows 7 x86)
    i downloadded this file ... startet--> and now error: DlPortIO.dll missing on the computer
    Please install the program new !
    need help
  6. tadythefish
    tadythefish Active Member
    Process automation engineer
    Slovenia
    677Coins
    download the plugin from the web
  7. Pixello
    Pixello New Member
    Student, Amateur designer and programmer
    Krosno
    449Coins
    3DOF, DC motor
    If u want to flash atmega you should download Atmel Toolchain or atmel studio, its easiest way to do it.
