Cheap ebay JGY370 motor
Discussion in 'Motor actuators and drivers' started by F1Nut, Aug 20, 2015.
  1. F1Nut
    F1Nut New Member
    Brisbane, Australia
    271Coins
    I would like to build something along the lines of the desk racer by bsft and am looking at motors.
    I figure I'll use the same ones from motion dynamics but am considering some really cheap ebay ones for testing so I don't destroy a perfectly good motor while I'm still unfamiliar with the way it all works.
    The cheap ones I found are JGY370 worm drive 12v for $17.
    With no load at 160 rpm the torque is .05Nm and stall at 0.2Nm.
    When geared for 40rpm (no load) they are 0.2Nm and 0.8Nm stall torque.
    So I figure the cheap ones won't be up to the task of driving the desk racer? Would they be enough for traction loss on a shoulder mount type rig?
    148,652Coins
    +10,914 / 54 / -2
    I think you need to set your sights higher and look at motor specs that are known to work.
  3. F1Nut
    F1Nut New Member
    Brisbane, Australia
    271Coins
    Thanks noorbeast - guess I'm just concerned I'm going to brick my first one :confused:
    148,652Coins
    +10,914 / 54 / -2
    You are not likely to brick a motor, more likely that in the excitement of the moment you don't double check wiring and do something silly like burn a board. The electronics are far more delicate than motors.
