cheap scn5
Discussion in 'Off Topic - All other stuff here' started by adgun, May 10, 2009.
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,778Coins
    hi
    Dyadic got new actuators scn4
    they are the same lyke scn5 but 25,00 usd. cheaper and got plastic housings
    Look @ automation4less
    meaby Mirai will deliver them to .
    And save some money
    regards Ad :hi:
  2. tronicgr
    tronicgr
    :eek:
    ???? Where is that? Link?
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,778Coins
    Hi Thanos
  4. RaceRay
    23,876Coins
    the SCN4 are as new as the SCN5 :D Look at the specs..they are from 2004.
    Nevertheless i wouldn´t recommended to use them only to safe 25 bucks. Not only the casing is made from plastic, also the threat and i estimate the nut, too. That means too much abrasion and fewer long life cycles.
