cockpit Genesis F1
Discussion in 'SimTools compatible interfaces' started by alpefe, Oct 18, 2012.
  1. alpefe
    alpefe Member
    - 17Coins
    hello again, this time I decided to open another post specific, because it is simple it is a new development for fans of F1, it is a specially designed F1 cockpit as such is specifically designed for this use being outside other specialties, everything is designed to fit as much as possible to its actual counterpart, logically there are a number of limitations, such as the steering wheel, you can not have exactly the same position that a real one is behind the wheel of the cane direction, occupying far less than one of the commercial flying games, and then the seat, are tailor-made for each rider, sport seats manufacturers do not market these seats, though the truth is that they are equal to the commercial bucket except the position of the head, so if we put a fixed support, made this clarification continuous.
    sustaining the main structure is based on a perimeter fence in industrial perfileria 50X100mm that gives high rigidity, high configurability besides, we can put the pedals as we like, high, low, forward, back, incline, etc. .. compatible with all.
    seat inclination can be varied by varying profiles rear seat base and then would go the headrest.
    the steering wheel can be up, down, forward, rewind or tilt, to avoid having to go over and have a more suitable access (we are at home) entered by the side and help us have a handle on top, in the same profile, you can lock the keyboard and mouse, because as F1 not need many knobs (not to say that you can not put more) of echo can put an Ipad or tablet holder.
    passed to the image, the system uses the same of his counterpart, so we can put whatever you want, upload, download, zoom in, zoom out, change the angle of the ends and put an upper deck to get a better immersion, or that also saying that you can put other speakers and wherever we want, also comes standard with support for CPU, and more accessories possibility.
    and finally another reason for this type of structure, a motion system that helps us more to total immersion, this would consist of 4 drives with paths 400mm/seg 200mm. travel speed to recreate behavior as real as possible within the domestic use, its size is 190X130X100cm that is quite content to be F1, and in case anyone wants to know the estimated price output is 899eu motionless., that seeing what's on the market this very well, it is my opinion, I hope you like it.
