Codemasters F1 2010 profile
Discussion in 'Archived information' started by ledfoot, Sep 23, 2010.
  1. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Designed for 150mm SCN5's
    For use with 25% limiter enabled in SCN5 plugin
    Speed 22500, Acceleration 600 set automatically in Synaptrix
    Ledfoot CM F1 2010 Stage ii 1.0.rn2
  2. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Sorry guys, I posted the wrong profile initially. The correct one it here now.
  3. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
  4. Popeyin
    Popeyin Member
    Truck driver
    Barcelona,Spain
    108Coins
    hi,i have the steam version and i cant run with motion.
    i open the force-sender and force profiler 2.0.8.9b
    load the Ledfoot CM F1 2010 Stage ii 1.2 soft.rn2 profile in the profiler
    in the force sender, i select dirt2 plugin and game executable G:\Program Files (x86)\Steam\steamapps\common\f1 2010\f1_2010.exe
  5. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    There is another Codemaster directory under MY DOCUMENTS There is the same file, and there you have to modify it. (IP 127.0.0.1 and extradata=1)
  6. Popeyin
    Popeyin Member
    Truck driver
    Barcelona,Spain
    108Coins
    i think you says the:hardware_settings_config. xml file
    i edited but i have the same problem
  7. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Go to: ...mydocuments/mygames/codemasters/f12010/hardware_settings_config. xml
    Depends on your os, but it should be in your mygames/codemasters dir.
    So NOT the file in the game directory!
    @ledfoot: thanks for the profile!
    Regards,
    Rob
  8. Popeyin
    Popeyin Member
    Truck driver
    Barcelona,Spain
    108Coins
    in steam version is in my documents/my games/formulaOne/hardwaresettings.
    this is my .xml
  9. splendiddd
    CCTV security
    Netherlands
    810Coins
    Change 127.0.0.0 to: 127.0.0.1
  10. Popeyin
    Popeyin Member
    Truck driver
    Barcelona,Spain
    108Coins
    thanks,i worked this night and my mind is a little dirty. now run´s
  11. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Video for this profile:
    http://www.youtube.com/watch?v=779UQTWBfhI
  12. yojalil
    yojalil New Member
    MEXICO
    247Coins
    2DOF, SCN5
    HI, CAN I USE THIS PROFILE WITH SCN5 100MM ?
  13. Fahim
    Fahim Member
    235Coins
    Yes, can we try this with 100mm ?
  14. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    I highly recommend using the 25% limiter. However, a 100mm actuator can perform similarly to a 150 with the limiter off, but not quite as precisely.
    NOTE: I have witnessed incorrect (too high) speed and acceleration values destroy an actuator!!!
    The optimal scenario is to use 150mm actuators with greater angles and the limiter. The greater angle means more granularity of your motion because you can have the same degrees of seat movenent but utilize more actuator travel to achieve it. This provides the best feel . It also provides the best safety.
    You should always use a limiter if you can!
  15. Fahim
    Fahim Member
    235Coins
    For some reason every profile bar FAGS program I use with x-sim is like shock horror to the point i got to switch it off after 2 seconds. Because it feels like the actuator will rip through my spine.
    My speed setting is always on 10000 and acc at 512.
    I just dont know how to alter somes profile so i can decrease the foward and bacward movement.
    I want to use ledfoots profile for F1 but is unplayable because of foward and backward movement is too much and too sharp. How can I tone it down further please?
  16. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    To reduce Longitudinal movement (forward/back), decrease the percent of intensity of effect 27. To reduce lateral movement (left/right), decrease the percent intensity of effect 25.
  17. bvillersjr
    Ohio, USA
    437Coins
    @ Fahim,
    The one size fits all approach of the plugin you are using will cause that type of problem for certain.
    What you are suffering is the issue of actuator angles that are different from what everyone else is using, not necessarily the issue of 100mm vs 150mm. For example, if in Ledfoots sim, a longitidinal movement of x caused 5 degrees of movement a lateral movement of x also causes 5 degrees of movment, his profile will feel much different on a sim where a longitudinal movement of x causesd 10 degrees of movement and a lateral movement of x causes 2 degrees of movement.
    If anything, his profiles should have less movement on your simulator, not more given that the two of you had matching geometry.
  18. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I also agree that actuators can be damaged by having incorrect actuator angles, a heavy passenger and high speed and acceleration values. Never run without the 25% limiter unless you have taken appropriates precautions within the profiles by properly scaling the effects or adding limiters within the math table.
    ....Mike
  19. Fahim
    Fahim Member
    235Coins
    At last made progress. Managed to tone down the movemet. Like the investigater mr columbo. Just waaaaan more question
    Can I leave my speed and acc to default:
    Speed 10000
    Acc 512
    At all times, regardless of any profile. These seem to be quick enough for me.
  20. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    The Settings in the synatrix will override any settings that you have in the SCN5 plugin. You can change the settings in the synaptrix or delete them and it will use the settings in the plugin instead.
