compatibility
Discussion in 'Force-Profiler Simulator Control' started by sharky, May 27, 2008.
  1. sharky
    sharky New Member
    1Coins
    hi all!
    yesterday i installed all the softwares, and now something worries me. i saw that when i start a game there is sort of a injection, at least i have to select the proper exe file. what worries me is that i use the iz3D stereoscopic drivers which also inject in the DX to generate a 3D image.could there be a conflict between both? or probably not since the iz3d uses visual informations and the FP uses movement informations?
    is there somebody who has 10 minutes of time who could try it? i dont have my simulator yet else i would try. for who is interested in trying:
    dowload the latest iz3d drivers from http://www.iz3d.com or http://www.mtbs3d.com set them up, open the control pannel, set the output to anaglyph (else you wont be able to play without an iz3d monitor or other setups) set the drivers to enabled and try to start a game... if everything works fine, then you should have your sim working as usual, and the ingame image should be doubled with red/blue images. (like those for the red/blue glasses)
    thank you
    igor
