value1
condor The Competition Soaring Simulator Plugin 2.0.1.1
SimTools plugin for condor The Competition Soaring Simulator
  1. value1
    14,751Coins
    condor The Competition Soaring Simulator Plugin - SimTools plugin for condor The Competition Soaring Simulator
  2. Historiker
    Michigan USA
    9,195Coins
    You were and are still my Hero Value1! Excellent!
  3. value1
    14,751Coins
    value1 updated condor The Competition Soaring Simulator Plugin with a new update entry:
    Update to include GameVibe support
    Read the rest of this update entry...
  4. ClubVueloUPM
    ClubVueloUPM New Member
    Students
    Madrid
    70Coins
    Hello! we are unable to patch the condor, as we try using the game manager it show a message saying game did not patch? and nothing on the directory changes.
    Does simtools use the known udp.ini (enable=1, etc) to obtain the data or it writes anything on the condor directory?
    147,956Coins
    +10,883 / 54 / -2
    Perhaps @value1 can advise.
  6. ClubVueloUPM
    Students
    Madrid
    70Coins
    Problem solved, we simply created an archive named Condor.cfg (following the example of live for speed) on AppData\Local\SimTools\GameManager\GamePathSaves with the Condor path on it and changed the port on Condor/UDP.ini to the one showed on the Profile Editor of the Game Manager.
  7. value1
    14,751Coins
    During patching GameManager should create a file UDP.ini in the Condor2 subdirectoy …\Condor2\Settings with the following content:
    Code:
    [General]
    Enabled=1
    [Connection]
    Host=127.0.0.1
    Port=4123
    [Misc]
    SendIntervalMs=17
    ExtendedData=0
    LogToFile=0
