Dirt 2
Discussion in 'X-Sim² profiles' started by Schnullerbacke, Feb 21, 2010.
  1. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Hi guys,
    with the greatest support of Niels (Nima), I created a new profile for Dirt 2 :yippiee: !
    I just published the profile and all the specs in a new posting on my site http://www.sim-parts.com - please follow this link to get there directly: http://www.sim-parts.com/?p=481
    Here are some specs:
    • X-Sim version: 2.1.0.12
    • Sim hardware: SCN5 Motion Simulator
    • Actuators: 100mm
    • Game: Dirt 2
    • Designed for specific vehicles/tracks: NO
    • SCN5 Interface Settings:
      - Speed: 22.500
      - Acceleration: 400
    • Synaptrix settings: NO
    • Used plugins:
      - SCN5
      - Bass Shaker
    • 25% Limiter: NO
    • Percent Scaler: YES (90)
    • motion section in the hardware_settings_config.xml:
      - enabled: true
      - ip: 127.0.0.1
      - port: 20777
      - delay: 1
      - extradata: 1
    • OS: Vista 64
    • Dirt2.exe: run as administrator
    We still have to modify some values, e.g. the collision values - but I think, it rocks awesome ;-)
    And here are two short clips (Croatia and Japan):
    http://www.youtube.com/watch?v=BxTqJF7JRwA
    http://www.youtube.com/watch?v=MQDREWV6V_4
    Enjoy it - and feel free to leave some feedback (http://www.sim-parts.com) :cheers: !
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Looks fun.
    Are you using the boxed version or the Steam version? I haven't had any luck getting the Steam version working yet.
  3. Schnullerbacke
    Germany near Munich
    369Coins
    Hi Berney,
    I'm using the boxed version !
  4. LearnDriver
    LearnDriver New Member
    The Netherlands
    The link to the file on your website gives a 404 error :(
  5. minikase
    minikase Member
    359Coins
    Awesome Profile! I drive it with Speed 4200 an Acc 380...for me that´s more than enough.
    THX to Chris and Nima for this very good work.
  6. Schnullerbacke
    Germany near Munich
    369Coins
    @Learndriver: I cannot follow what you are talking about - all links work well, the save as dialog as well... did you try it once again ? For me everything works great here :? !
    @minikase: Thanks, m8, for your feedback ! I'm glad you like it :cheers: !
  7. LearnDriver
    The Netherlands
    In both IE8 as FF3 I get the error:
    So for some reason it add's the /sp/ part. If I delete that it works fine on your site aswell :?
  8. riton
    riton Active Member
    1,006Coins
    I have a simulator with gear box motors, SCN5 profiles are not correct for me.
    I use the same settings for testing, I just use values , it is difficult to understand without trying some adjustment.
    there is much difference between the 2 profiles on the first and this one.
    methods are also different
    how you choose those values? you based on the values of auto-adjust?
    and how do you test for the values you choose?
    I personally test each effect individually
    can you explain how you do it to put all these effects?
    and why the filter?
    this could help me understand and make good profiles
    I take each effect, I record the auto values , then I must reduce the value to 5 digits to the max and 4 digits for the minimum
    for example effect 27, the maximum auto value : 1572323, I took 157232
    minimum value for the car: 15723 I took effect in 1572 and are good
    for the filter is difficult to understand the result, and the sensations obtained
    i have no setting same you for my motor, i just use the velleman card and dynamic speed
    •SCN5 Interface Settings:
    - Speed: 22.500
    - Acceleration: 400
    my problem: the values of effect does not give a sufficient sensation of speed for my simulator
    I must reduce the values
    there another way?
    thank you
  9. Schnullerbacke
    Germany near Munich
    369Coins
    Hi riton,
    unfortunately I don't know the behaviour of a motor powered sim like the one you have, so I also don't know how to set up the values :? !
    Basically you have to take every value separately and drive it with auto max and auto min, to get the maximum and minimum values.
    Then you save the value and go on with the next one.
    After that you know every value and can start mixing it up resp. building a new profile. Remember that one value can affect another value, e.g. the drift value changes the behaviour of the former set left/right value. There are many things which have to be considered.
    I think the best way is to start over with a new profile. Start with the values 25 and 27 and then try to add the other values step by step. If there are any questions left, let me know ! I try to help you out - and I think that Nima will also give you as much hints as he can give - he has imho the biggest knowhow in building proper profiles here.
  10. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    531Coins
    thanks chris and karsten,
    i have order dirt2 now than i can test it self.
  11. riton
    riton Active Member
    1,006Coins
    thank you
    without your advice, it is difficult to be on the correct method to make a profile
    until now I do as you said
    but it is precisely the combination of the effects more difficult, and correction, better effect then when all the effects are mixed
  12. Schnullerbacke
    Germany near Munich
    369Coins
    @Niels: Na ENDLICH - habe mir ja nun schon den Mund fusslig geredet :clap: ! Dirt 2 wird Dir gefallen !
  13. Schnullerbacke
    Germany near Munich
    369Coins
    @riton: You're absolutely right, the combination of all effects has also to be considered. Start with testing each effect separately, so you better know which value causes this or that effect. After that you can play with the values - try different settings and look what happens. When you have a profile with many values, like the one that Nima and I have created, it will become very difficult to see what you have to change if e.g. the acceleration in curves isn't enough or if there is too much rumble while driving over gravel road... Try to stay with our order of the values, otherwise one value will affect another value and you won't know, which value has to be corrected...
    It's not that easy (I'm at the very beginning of creating profiles too !), but it's great to create your own profile ! I like our Dirt2 profile very much ;D !
    :cheers:
  14. riton
    riton Active Member
    1,006Coins
    patch 1.1 Clubic [359 Mo]
    http://www.clubic.com/patch-jeux-video- ... irt-2.html
    Citation
    DiRT2 Patch Change Notes
    Bug Fixes
    Graphics
    • Shadow quality setting of “low” is now correctly saved instead of resetting to “medium” Combinations of both high resolutions and high MSAA levels have been restricted on graphics cards with low memory to prevent issues found with those settings
    • Added missing function key icons
    • Fixed several lighting artefacts in night races
    • Fixed missing initial load screen on multi-GPU setups under DX11
    • Alt+Tab and Alt+Enter are now better supported under DX11
    • Benchmark mode now correctly applies custom settings
    • Fixed missing text in benchmark mode pause menu
    • Fixed a crash when changing multisampling mode
    • Fixed flickering text on stats screen in network mode
    • Improved image sharpness in DX9
    • Fixes to improve NVIDIA 3D Vision support
    • Better default graphics options are chosen when running the game for the first time with a GeForce 8400 GS
    Audio
    • Fixed an issue where replay music would suddenly cut in when navigating a replay at very slow speeds
    • Ensured that OpenAL is properly shut down when exiting the game using Alt+F4
    • Prevented reverb cutting in and out abruptly on the Utah tracks
    Gameplay
    • Fixed player being able to drive through the ground on the Rewang Trailblazer track
    • Fixed wall-riding on Battersea routes
    • Bug-fixes for LA Stadium, Malaysia Rally and Baja Rally tracks
    General
    • Fixed a rare crash during the loading sequence
    • Fixed an issue in the Russian language version where the default player name is missing from the one-to-watch sequence
    • Fixed an issue where loading and saving would fail if multiple controllers were connected
    • Fixed a crash which could occur when entering the first race using a motion platform
    Changes
    • Removed 16x quality coverage sampled anti-aliasing support
    • Added support for MS Sidewinder Force-Feedback USB Wheel
    • Added support for Logitech Driving Force USB Wheel
    • Added support for Logitech Cordless RumblePad 2 USB controller
    • Machines with 6 cores will now use the 4-core worker map rather than the single core map
    Optimisations
    • Optimised shadow rendering
    • Optimised CPU performance on machines with SMT and multiple cores
    • Improvements to frame-rate fluidity and triple-buffering support
  15. johnakar
    johnakar Member
    6Coins
    Hi Chris,
    I am trying to use your profile for Dirt 2, but had no luck. Could you please tell me which game plug-in shall I choose in the Force Sender? Another thing is that I do not have a bass shaker, so when I load the profile, I got a pop up message from the Profiler, how can I deal with it? I have made of course all the necessary changes in the hardware-config.xml file of the game.
    Many thanks.
  16. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi john,
    in the sender you mast have dirt2.if you dont see the dirt2 plugin you mast have a newer x-sim version.in the pop up messarge go to quit program than by fatal error
    on no and than ok.again for the bass value.than you have no output on soundcard.
    now go in the mathsektion and delite both bass axis and save it.
  17. johnakar
    johnakar Member
    6Coins
    Hi Nima,
    Lucky to found you online. If I understood your reply well, the plugin is not needed? If it does where can I get it?
    Many thanks,
  18. Nima
    Glaser
    Bad Zwischenahn
    531Coins
  19. bvillersjr
    Ohio, USA
    437Coins
    Hi John,
    I believe that you have the Commander and the SX-3000, so you will not need to worry about the config settings. THis is done automatically by the Commander.
    However, I think that this plugin is a work in progress? and is not officially released or fully tested yet.
    :cheers:
  20. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Hi guys,
    Since some time of absence i am back in xsim racing... I have tried your profile Chris and its great and very smooth! my standard Dirt2 Profile for now;)
    Do you also play RBR?
    Regards
