dirt 3 crashed if I change extradata 0 to1
Discussion in 'DIRT 1 - 3' started by chris62, Dec 14, 2011.
  1. chris62
    chris62 Member
    - 9Coins
    I have a problem with dirt 3. If I use my sim with the dirt 2 plugin, after modification of the hardware settings my sim is workng fine. But I can´t finished each race because if I came to the finish, the game stops and and I got a picture freeze.
    When I change the hardware settings back I can drive without my sim with no problems. I have no idea about the reason.
    Any help would be very great.
    cheers chris
  2. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
  3. chris62
    chris62 Member
    - 9Coins
    hi,
    thanks for this information. But if I put my system to the 1.1 patch I have no chance to run it together with xsim because after start of the game the system will have an upgrade. If I run the game without this upgrade the hardware setting goes back to the basic setup (dbox...extradata 0) automaticly.
    I guess after the live upgrade my system will run with the 1.2 patch again. :sos:
  4. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Is It Steam version ? You can switch off auto update in Properties.
  5. chris62
    chris62 Member
    - 9Coins
    No, it is the boxed version.
  6. prosimu
    prosimu Member Gold Contributor
    - 870Coins
    Put the patch 1.1 and remove the autosave of DIRT3.
    Leave you game
    Change the hardware setting and launch your game.
    Then Play!
    Put the autosave
  7. chris62
    chris62 Member
    - 9Coins
    Ok, I try! I will come back with the result.
    Many thanks
  8. chris62
    chris62 Member
    - 9Coins
    I have gone the described way, but unfotunately my Dirt 3 version turned back the hardware setting to dbox and extradata 1 as soon as I started the game. I have no idea what was wrong. :thbd: :no:
    Probably it is the boxed version and not the steam version.
  9. riton
    riton Active Member
    1,006Coins
    what is the solution to run DIRT 3 without the crash at the end of race?
    I have DIRT 3 BOX with the Patch.
    if i don't patch , i have some problem with the game backup
  10. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Yee... the only way at the moment is to keep this game without latest patch. This will keep you going but you have to set your steering wheel settings every time when you start new game.
    We are still waiting for new patch which may solve this issue.
  11. riton
    riton Active Member
    1,006Coins
    ok,... thanks
    i try to use with any patch... :thbd:
    with any patch there are a problem with the save game.
    for the steering , just press start in the shifter.
    If you press enter there are a problem to set the steering, but if you press start it's ok
    :hi:
  12. bsft
    Dirt3 works well here, no crashes and no save problems and all motion. I just have to re-do the wheel settings when I start, mind you, I am using a home made sequential shifter as well as separate wheel.
  13. bsft
  14. riton
    riton Active Member
    1,006Coins
    with the latest patch 1.1 , it does not work .
    there was a crash at the end of the race.
    In any version of Dirt 3 it works for you?
    in original box version there is a problem with the backup.
    but the simulator works.
  15. riton
    riton Active Member
    1,006Coins
  16. riton
    riton Active Member
    1,006Coins
    DIRT 3 is ok with patch 1.1 and Live4speed sender plugin
    now it's ok with this config:
    plugin “live for speed” in sender.
    for motion :
    \my documents\my game\DIRT3\hardwaresettings\hardware_settings_config.xml
    <motion enabled=true ip=127.0.0.1 port=4123 delay=1 extradata=0
  17. Shadoogie
    Shadoogie New Member
    Has anybody got this game to work without crashing at end of race, using the Sim Commander 3 setup?
  18. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    I`ve change to retail version and didn`t update at all. Everything works witch this settings and x-sim software:
    <motion enabled=true ip=127.0.0.1 port=20777 delay=1 extradata=1 />
  19. bsft
    This sounds like an odd issue relating to one user, kinda sounds like my problems playing GRID either on xp or 7, crashes only for me............
  20. museumsteve
    museumsteve Member
    Retailer
    136Coins
    2DOF, SCN5
    I'll try this, because of GFWL I cannot use motion and still accept game updates :(
