DiRT motion video
Discussion in 'Commercial Simulators and Peripherie' started by SimHawk, Nov 1, 2007.
  1. SimHawk
    SimHawk Member
    Engineer
    Norway
    Anyone seen this?
    http://www.youtube.com/watch?v=xzFrg-OPw5Y
    After tweaking DiRT to be more realistic. The Escort Mk2 is a blast! Anyone tried DiRT with X-sim? I'am surely going to when my sim is up and running.
  2. mboRacing
    mboRacing Member Gold Contributor
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Hello Sim Hawk
    I'm at work to find the offset's for dirt. At this point i have speed, rpm, gear, Turbo charge, wheel speed, x and y g-forces. i hope that sirnome test this values next weekend...
  3. SimHawk
    SimHawk Member
    Engineer
    Norway
    Very good! Let us know when you have something to try. The G-Forces should in theory be enough to control the sim should'nt it?
  4. tronicgr
    tronicgr
    In the decription of the video it states the following:
    About This Video
    cmr dirt working with motion 'sim'
    simply edit C:\Documents and Settings\All Users\Documents\Codemasters\DiRT\hardwar esettings\hardware_settings_config.xml
    change the line motion enabled=false to read true and setup your motion software accordingly
  5. SimHawk
    SimHawk Member
    Engineer
    Norway
    I saw that too, but where does the motion data go? Does that mean it has an interface for motion extraction? I did a quick search on google, but did not find anything.
  6. tronicgr
    tronicgr
    Yes I did found nothing too.
    But I found its readme!
    [​IMG]dirt_readme.txt (11.88 KB)
    On the end it says:
      Advanced Features
      If your system has a motion platform, then DiRT™ should be able to control it. This feature is completely untested beyond checking that the basic data output is correct, and as such should be used entirely at your own risk. The output format is designed to be compatible with the Live for Speed outsim motion platform format. To enable, just open the system\hardware_settings_config.xml file and edit the motion attributes:
      <motion>
      enabled – Set “true” or “false” to enable or disable the motion platform
      ip - The IP address of the motion platform
      port - The port of the motion platform
      delay - the time between data updates from the game (1/100ths second).
      extradata - This should always be set to “0
    Notice the LiveForSpeed reference!!!!!!!!
    Too bad I dont own DIRT yet to give it a try with the existing LFS plugin!!
    Thanos
  7. SimHawk
    SimHawk Member
    Engineer
    Norway
    Wow! Great finding! :D :idea: I definitely will test this tonight!! (If my 8 weeks old son is letting me.... and not crying)
    BTW: If you like rally I recommend DiRT. With tire grip reduced to 80%, sim-brake mod and car tuning I have a lot of great time with this game!! RBR has been played very little since DiRT.
  8. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Sound's realy good :) but can anyone tell me what a port adress i should use for the force sender?
  9. tronicgr
    tronicgr
    These are the defaults that LFS plugin is using:
    IP 127.0.0.1
    Port 4123
    Regards, Thanos
  10. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    ok - i tried - but the my game always frees'es while race'n :-(
  11. SimHawk
    SimHawk Member
    Engineer
    Norway
    Hmmm... does not work right out of the box. Tried with the settings above. :( No life in the outsim window.
  12. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    But your game is still running without problems?
  13. SimHawk
    SimHawk Member
    Engineer
    Norway
    Yes it is! I am currently searching for a program that can monitor the port 4123 to see if DiRT is sending anything at all.
  14. tronicgr
    tronicgr
    Maybe it needs a second PC for the Profiler. I encountered such problems when tried to test IL2 1942 before.
    And DiRT is a little heavy game that takes almost all the resources of the PC...!
    Thanos
  15. SimHawk
    SimHawk Member
    Engineer
    Norway
    I have a dual core cpu and the profiler was running on my laptop. Only force sender was on my game pc.
  16. SimHawk
    SimHawk Member
    Engineer
    Norway
  17. SimHawk
    SimHawk Member
    Engineer
    Norway
    Dirt with outsim - Working!
    I just managed to capture DiRT motion data! :razz:
    I found out that I had edited the wrong hardware_settings_config.xml
    file. The one under DiRT's install/system is for default game profiles. Another file is located under
    C:\Documents and Settings\All Users\Codemasters\DiRT.
    When I did that DiRT froze! Hmm.. back to drawing board. Since I have my own little outsim listen application I changed the port number to 20777 which was the default from DiRT installation. That made the trick!
    Now we just have to make the LFS plugin have the option to change port.
  18. SimHawk
    SimHawk Member
    Engineer
    Norway
    I posted another post under force sender /plugin forum, since this is clearly on topic not off topic anymore. Read on from there.
