RaceRoom Racing Dirt Rally - no 720p resolution and pCars no triples
Discussion in 'Virtual Racing League' started by Pit, May 17, 2015.
  1. Pit
    30,439Coins
    Hi guys, I ordered Dirt Rally PreRelease, installed our PlugIn, and then, then, then I had to swallow hard. No 720p resolution , no 120Hz gaming at 3800x720 pixel using my projectors, WTH. They have simply forgotten to include 720p as a resolution. NOOBS!
    EDIT: Later today I was looking for pCars and then - I had to swallow hard, again! There is no support for triples. I thought there was much time spent looking after visuals. NOOBS!
  2. SilentChill
    20,557Coins
    Just alter the config files manually for Dirt Rally im sure that would work so you can get the correct res.
    And Pcars deffinately supports triple screens !!
  3. Pit
    30,439Coins
    Already tested, does not work.
    You cant justify the angle of view like in Assetto Corsa, ergo IMHO triple screens are not supported. Anyway thank you @SilentChill for your tips.
  4. Pit
    30,439Coins
  5. value1
    14,751Coins
    You can run pCars in tripple screen mode up to 11'520×2'160 (= 3×4K).
    You might need 4×SLI Nvidia Titan :D
  6. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Thanks Pit.
    I was thinking about buying the game, I will wait now, I have AC, I can wait ;)
  7. Pit
    30,439Coins
    @value1 triples are running but you cant justify the correct FOV, f.eg. the right mirror is out of the screen and the dashboard is warped like a banana :p
  8. bsft
    Pcars is ported to console, so good luck if it ever gets an update supporting 3 screens. I have seen very few console - pc ported games support 3 screens. Mostly codies games and some EA games.
  9. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    89Coins
    bummer for no triple screen support.. AC and iracing are a perfect example how it should be done!
  10. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    You can set this in cfg file in C:\Users\USER\Documents\My Games\DiRT Rally\hardwaresettings .
    This is in win7 but you get the idea.
    <resolution width="1024" height="768" aspect="auto" fullscreen="false" vsync="0" multisampling="4xmsaa"> EDIT this
  11. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    48:10 if monitor is 16:10 48:9 if 16:9
    <resolution width="3800" height="720" aspect="48:10" fullscreen="false" vsync="0" multisampling="4xmsaa">
  12. Pit
    30,439Coins
    ah an older thread has been digged out...you are right, in the meantime surround. Only 3D is crashing from time to time...the screen collapses back to 2D.
