DIY 2 DOF - First Time Builder
Discussion in 'DIY Motion Simulator Projects' started by Sean Philpot, Jun 15, 2016.
  1. Sean Philpot
    Sean Philpot New Member
    Adelaide, Australia
    257Coins
    I am new to the forum and plan on building a 2 DOF shoulder seat mover, i have seen a few other threads on here that feature Arduino - Moto monster Shield combo. The particular build i have been referencing had 2 motors controlled by the single MM, and a single PSU.
    Is this ideal? and/or why do people use 2 PSU/ 2 MM? I have ordered the arduino and 1 x MM, plus i have some 180 degree pots coming. I still need to purchase the PSU and i want to use 12v Worm drive motors. Does anyone have any recommendations or tips before i commence to far. Will post updates as i build!
    148,640Coins
    +10,909 / 54 / -2
  3. Sean Philpot
    Adelaide, Australia
    257Coins
    Ok Thanks.
    I have purchased the DX R1206 UNO / DX Monster Moto Shield for Arduino board, i intend on running 2 x worm drive motor 12v 200 w, 180 rpm, they are rated at 16 Amps at 12 V and are available from motion dynamics. So i am hoping that i can use a single server PSU or similar with an output of say 47A 600W etc. does that sound reasonable, im a total noob!
    148,640Coins
    +10,909 / 54 / -2
  5. Sean Philpot
    Adelaide, Australia
    257Coins
    Thanks man, Very much appreciated. I feel this will be a fun little project!
    148,640Coins
    +10,909 / 54 / -2
    It will indeed be a fun project.
    You also have some other active members located around Adelaide, like @GIB SimRacing and @Alexey, which may be handy.
  7. Sean Philpot
    Adelaide, Australia
    257Coins
    How well do the car batteries handle the constant load? Do you use a deep cycle battery with a trickle charger of some type? Car batteries are pretty costly compared to buying a server pau or something similar I imagine. Is it purely the amperage that is making you go down this path? What are he pro's/cons?
  8. Historiker
    Michigan USA
    9,201Coins
    Batteries work very well indeed, and most or the original builders started out using them and indeed still do. @eaorobbie has some great information in his threads on using batteries.
    I used to use a deep cycle battery with mine before I went over to PSUs. I used a trickle charger to keep it topped up. The only issue that I had was that with long sessions the battery would get low and I sometimes lost my motion. Again; eaorobbie has a few tricks to overcome these issues. Perhaps @noorbeast has a link? I really should start keeping a list myself one of these days :)
  9. Sean Philpot
    Adelaide, Australia
    257Coins
    What sort of time frame are you getting before it goes flat?
  10. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Hi @Sean Philpot - First up, welcome and good luck with your project.
    Personally, I haven't used batteries to power my sim. I am using two HP DPS-600PB 575W power supplies and they have been really good. But, I haven't looked into the Arduino and MM as I am using the JRK12v12's. So unfortunately, I won't be able to help you out with that one.
    Anything else, I will gladly try to help out where I can.
  11. Sean Philpot
    Adelaide, Australia
    257Coins
    Hi and thanks for the response! I don't think the battery route is for me, did you buy your power supply's on eBay and how much should I be expecting to spend on them? Definitley looking forward to getting the project going and will be posting photos as I go! It's a great community on this forum and I believe it's going to prove very helpful! Cheers!
  12. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    I just bought one for my project and with shipping came to $30 CAD. Hopefully just the one is sufficient for the 2 PGSaw motors.
  13. noorbeast
    148,640Coins
    +10,909 / 54 / -2
    I originally got second hand HP PROLIANT 575W PSUs from Ebay at AU $39.90ea, though I later replaced them with brand new units from Ebay at AU $49ea, which were in their original boxes and wrapping, so you just need to keep an eye out for bargains: http://www.xsimulator.net/community/threads/dx-racer-compact-simulator.5866/page-19#post-92411
  14. GIB SimRacing
    Barossa Valley, SA
    983Coins
    I got 2 of those power supplies for $60 from ebay as well. They were second hand but have been running for a while now so I think it was worth the money.
    Like @noorbeast said, keep an eye out for them and you will find some at a good price in no time.
