1. We have a few rules which you need to read and accept before posting anything here! Following these rules will keep the forum clean and your stay pleasant. Do not follow these rules can lead to permanent exclusion from this website: Read the forum rules.
  6. Do not share user accounts! Any account that is shared by another person will be blocked and closed. This means: we will close not only the account that is shared, but also the main account of the user who uses another person's account. We have the ability to detect account sharing, so please do not try to cheat the system. This action will take place on 04/18/2023. Read all forum rules.
DIY FFB wheel base
Discussion in 'DIY peripherals' started by Mantarochen, Oct 25, 2023.
  1. Mantarochen
    Mantarochen New Member
    27Coins
    Hello all!
    I am currently trying to build my own FFB wheel base. The wheel base I was going for is belt-driven, maybe there is a chance to upgrade to dd in the future. For now it would make me more than happy to complete the belt-driven base.
    Maybe some of you can help me out with the questions that came to my mind.
    The hardware I am planning to use is the following:
    DC motor: MY6812 24V 150W
    Motor Driver: Cytron MD30C
    Controller: STM32F407VET6
    Firmware: EMC
    Now my question is, what PSU I should go for?
    I read, that the stall current will be really high if ffb is on 100%. What specs should it have?
    Would it be better to put two motor drivers in parallel to reduce the current between a single driver and the dc motor?
    Thanks in advance. Sorry if I forgot some details that are worth noticing here.
  2. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    438Coins
    Hi, I use the same motor and BTS7960 for the driver.
    Using a cheap switching PSU 24v 20A, and put 100% in EMC software but 60% on each game.
    it never stall. but if you want a better result, you can search for a MEAN WELL Switching Power Supply.
    its a known brand
    btw, good luck on your project!
  3. Mantarochen
    27Coins
    Thank you for your response. I hope to get it done in the near future so that I can finally use my rim that I already finished.
    What is the gear ratio of your build and what torque do you get out of it?
    My idea was a ratio of at least 1:10.
  4. itsumairu
    Psychologist
    Indonesia
    438Coins
    I use a 110 : 15 pulley. don't know what torque it made, but its enough.
    just remember, higher the ratio it will be more torque but slower on speed. and vice versa
