DIY motion simulator - How many PC's required?!
Discussion in 'DIY Motion Simulator Projects' started by Harry Woodhead, Apr 25, 2014.
  1. Harry Woodhead
    Harry Woodhead New Member
    256Coins
    AC motor, Arduino, Motion platform
    Hi Forum members,
    I was just wondering if any one could point me into the right direction regarding how many pc's are required to get a motion simulator up and running. On other threads, people post diagrams with 2 pc's in it?!
    If anyone could help me I would be most grateful,
    Harry
  2. Nick Moxley
    17,055Coins
    You only need one PC, No clue where you got the idea you need 2 from, But you dont. So Ya.
    Welcome to the forum.
  3. ferslash
    ferslash Active Member
    4,798Coins
    using the old software there were the possibility to use one computer to run your game, and then, connect that computer via net cable to a second computer, that proccess the movement calculations to your sim...
    as far as i know you can still do this but it is only recomendable if you have a really old or slow pc
    best regards
    fer
  4. Nick Moxley
    17,055Coins
    Interesting.
  5. value1
    14,797Coins
    • Useful Useful x 2
  6. bsft
    As I am spoilt for choice. I have 2 sims, I run one with gaming pc and laptop , as value1 says, easier to fiddle with numbers, and my other sim uses one pc only, just have to alt tab or run game in window to fiddle with tuning centre numbers.
    But a decent quad core machine is the way to go for a one pc setup.
  7. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I was intending to run everything off my overclocked Q6600 (quad core at 3Ghz) with 8800GT graphics card and 8Gb of ram.
    I 'think' once I do a fresh windows install and have it running it should be more than fast enough to handle everything on one machine but it's an interesting concept running a second PC for settings. I have a netbook which could be really neat and tidy and would be good for that. I assume it would be powerful enough to run everything from what I've read on the tutorial thread.
  8. bsft
    you should be fine wit all that, games will play ok. I have a mate whom has a 2.4 gig dual core intel, 4 gig ram and a decent graphic cars running everything. I am surprised that it does.
  9. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Just a thought here but could a raspberry pi be used to run the settings part of the sim or is it not powerful enough?
  10. eaorobbie
    20,440Coins
    Raspberry pi run a windows app ?:confused:
    BTW your machine shouldn't have an issue running it all SimTools is very light on the resources, if your setup can run a decent game then it shouldn't be an issue.:thumbs
    Machines I have tested - AMDx6-3.9 ,AMDx8-3.9,Dual Core 2.8 only one I had issues was a single core 2.4 with a decent video, Grid2 used to test with.
    And a done in Windows 8 and 7 both 32 and 64bit systems plus most ran an Ardunio dashboard too.
  11. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    ah yes, I need to get more sleep. :)
  12. bsft
    whats that?
