Question diy version dual pc operation
Discussion in 'SimTools DIY Version' started by kof3000ya, Sep 9, 2020.
  1. kof3000ya
    kof3000ya New Member
    taiwan
    - 2Coins
    The sim authorization code can only be set on one computer, how to use dual pc to run (game pc. sim pc)
  2. yobuddy
    49,198Coins
    You simply activate it on both PC's with the same registration details buddy.
    Take care,
  3. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    really ?in two PC?
    147,878Coins
    +10,879 / 54 / -2
  5. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
  6. yondwangmms
    yondwangmms Member
    - 151Coins
    Simtools can be activated on two computers with one registration information, right? Can only two or the same registration information activate more than two?
    147,878Coins
    +10,879 / 54 / -2
    SimTools can only be installed simultaneously on 2 computers if you are using the Dual PC control setup, see the SimTools Manual and the FAQ tips here to do so, and the SimTools EULA.
  8. yondwangmms
    yondwangmms Member
    - 151Coins
    Can I install simtools on two computers at the same time with only one activation code?
    147,878Coins
    +10,879 / 54 / -2
    No not according to the EULA.
    SimTools does have a limited number of reactivation, but that is meant to be for things like hardware upgrades, not multiple PC installations.
    You can use the demo version of SimTools, with the fully functional LFS for testing purposes on any PC.
  10. yondwangmms
    yondwangmms Member
    - 151Coins
    That means you have to buy two activation codes if you want to run simtools in dual mode. Do I understand that right?
    147,878Coins
    +10,879 / 54 / -2
    To be clear, as per my earlier reply, if you are using a Dual PC control setup, see the SimTools Manual and the FAQ tips here, you can do so using a single SimTools license.
    But, as per the EULA, you can't use a SimTools DIY license on multiple individual computers.
  12. yondwangmms
    yondwangmms Member
    - 151Coins
    I've learned that only when using simtools dual computer mode can two computers be activated with an activation code. It's not allowed at other times.
