Dof Output doesn't work anymore
Discussion in 'SimTools compatible interfaces' started by gigi, Dec 11, 2015.
  1. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    Hello!
    I just installed dashmeterpro on my PC and its app on a tablet. It's work perfect with dirt rally and assetto corsa. I do not know what happened, or rather what I Combined but now simtools does not work anymore. in game engine - output testing - Axis Output works but Dof Output doesn't work. In game simtools doesn't work anymore. what's happen?
    Thank for support
  2. Nick Moxley
    17,056Coins
    All else fails, Reboot and try again. Technically Dash meter shouldn't interfere with Simtools.
    151,991Coins
    +11,061 / 56 / -2
    I don't know anything about your rig but suggest you see if there is a port conflict, as DashMeterPro uses a network for connecting.
  4. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    I can not be sure that the cause is dashmeterpro. I did not use simtools a week. Only after tonight but 'after installing dashmeterpro and started a game using simtools I realized that is not working. if not e'causa of dashmeterpro Whatcan 'essereaccaduto? because axis output funzionae dof output is not working. where it can 'be the problem. mumblemumble
  5. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    yes noorbeast probably right...but How can I see if there is a port conflict?
    151,991Coins
    +11,061 / 56 / -2
    Are you using wifi or usb tethering for DashMeterPro?
  7. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    I use wifi
    151,991Coins
    +11,061 / 56 / -2
  9. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    unfortunately tethering my tablet does not work although when I connect I get ok pc does not recognize it. I tried with another Android device and does work. I therefore preferred to use wifi.
    151,991Coins
    +11,061 / 56 / -2
    Have you tried setting a different port number in the Advance settings of DashMeterPro and the accompanying configuration files for the computer part?
  11. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    Thank You norbeast for your support;)
    I unplugged the tablet and uninstalled the configuration file in the PC dashmeterpro but nothing has changed. The strange thing is that if I try the motors from Pololu utility (use cards jrk12v12) work perfectly. Although simtools in "output testing" "Axis Output" they work. But in "DOF outoput" they do not work instead. This makes me think that there isn't a problem with ports or USB cable. In any case most 'late I will try to disconnect and reconnect the USB cable and see what happens
  12. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    I tried to do these things in sequence:
    - Did pc restore from an image file created when everything worked perfectly
    - USB disconnected and reconnected.
    - Uninstalled and reinstalled simtools.
    - Uninstalled and reinstalled the Pololu utility for managing cards jrk12v12
    The software recognizes Pololu perfectly cards, I configured and engine works perfectly
    In simtools I reconfigured all. In "Output test" "dof output does not work but" axis output "works perfectly.
    I can not think that can be a problem of wiring or sockets or USB hardware in general. If so, the utility will Pololu simtools it should not see the tabs and engines, and instead see them work. Only "DOF Output" does not work and consequently even while playing the sim moves. bu "axis output work".
    mysteries of science
  13. gigi
    gigi Active Member
    915Coins
    2DOF, JRK, 4DOF
    Hallo! problem solved
    In axis assignment Game list "default" all forcewas at 0% and I not know why. I config all at 100% and sim work again.
    Thanks for support
