Question DOF3 axis settings...help!
Discussion in 'Commercial Simulators and Peripherie' started by wda24729, Apr 11, 2019.
  1. wda24729
    wda24729 New Member
    289Coins
    Hi - I have a Prosimu 3DOF with PRS200 actuators. Im slowly getting more familiar and confident with the settings so I decided to have a go with the Tuning Centre and now I feel like Im in a boat with the TL also all over the place
    Would anyone have any benchmark setting suggestions to get me started back on track (no pun), Im going around in circles being a sight technophobe. Maybe I mistakenly thought this was a plug 'n play thing!
    Thank you
    147,920Coins
    +10,880 / 54 / -2
  3. wda24729
    wda24729 New Member
    289Coins
    Thanks, although alot of that makes no sense to me Im afraid! I'll try and sit down and go through it slowly though
    147,920Coins
    +10,880 / 54 / -2
    Most of us started in the same place you are now, but with some research and support from the community learned how to refine moon profiles, which is part technological in understanding how SimTools functions and part art form, given we are dialing in a simulation of reality to match our own preconceptions and personal preferences.
  5. wda24729
    wda24729 New Member
    289Coins
    Thanks again,. Can I ask, as Im getting conflicting info, do I switch off all the actuators when I do my first run?
    Also, do I go around slowly within the track boundary making sure I don't hit kerbs etc? I was going to use a Mercedes 190 EVOII with sequential around Spa or Red Bull National as Im now familiar with them
    147,920Coins
    +10,880 / 54 / -2
    Your actuators should be on, try to go at about 80% of normal pace but don't hit anything.
  7. wda24729
    wda24729 New Member
    289Coins
    Still not getting this! I've read literature over and over again and its still not sinking it and I'm starting to loose interest as I spend more time trying settings than I do enjoying playing the games which was the idea of the purchase. Maybe I should have gone for that Versaro after all!
  8. BlazinH
    16,613Coins
    Imo your beef should be with Prosimu if they gave an expectation of plug and play. But it appears you increased tuning #'s making them weaker so try decreasing them instead.
  9. wda24729
    wda24729 New Member
    289Coins
    What Im struggling to understand is the manual states to set up default as shown on page 19 - DOF's 1-5 (attached)
    Then once the plug-in is installed, in my case AC, you set the assignments as shown on Page 23 (attached) with Axis's 3 and 4 still set but DOF's 4 and 5 not shown.
    My Axis assignments are Axis 1 - RH actuator, Axis 2 - LH actuator, Axis 5 - Traction Loss
  10. prosimu
    prosimu Member Gold Contributor
    - 870Coins
    First of all : do a tuning center : explain inside the doc.
    Second : reduce the main level (80-90) if you have a lot of informations from the game or increase if you want more.
    Then : if you want more movement (amplitude) : increase or decrease the slider for sways-surge : for the car behavior inside Game manager/editor. and increase or decrease the slider for pitch and roll for the road sensation.
    And finally : you could put more or less acceleration/speed inside game engine/interface settings if you need more or less impact from the actuators.
    Patrick
  11. wda24729
    wda24729 New Member
    289Coins
    Thanks Patrick, that's starting to make more sense.
    So as a couple of examples, what would I need to adjust for say:
    More kerb feel....
    Stronger gear change feel...
