Bug Double beep and the simu does not work randomly
Discussion in 'SimTools DIY Version' started by Lgars39, Oct 9, 2017.
  1. Lgars39
    Lgars39 Member
    Jura
    208Coins
    Good evening,
    Since my passage in v02, I sometimes encounter a problem when launching game engine ... when I run the simu from output type or when the game starts I have a sound (2 notes) and the simu do not answer. This is not systematic. This only happens since the switch to V02 ... Do you have a track? thank you in advance
    147,878Coins
    +10,880 / 54 / -2
    That sounds like a USB disconnect. Try launching SimTools first and then power up your rig and let us know if it still happens or not.
  3. yobuddy
    49,199Coins
    If its a long beep followed by a short beep then one of your interfaces could not startup.
  4. José Juan Hueras
    José Juan Hueras New Member
    Canarias
    151Coins
    Did you fix it?, I have the same problem and it is freaking me out!
  5. yobuddy
    49,199Coins
    Let's see if I can help buddy,
    Unassigned your interfaces from SimTools one at a time restarting simtools each time to check if it has stopped.
    Once you know where the error is, check the wiring and replace USB cables etc.
    Re-assign the interfaces and try again.
    Take care,
