Error opening Usb com port (ftdi chip)
Discussion in 'Force-Profiler Simulator Control' started by herctrap, Oct 10, 2010.
  1. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    I upgraded that
    http://www.youtube.com/watch?v=QSElXKtEZRM
    form serial to usb connection
    but my problem is that
    when i am tring to send data to the controller then the profiller says
    Error on opening comport #
    when the comport is a serial hardware comport there is no problem
    but on usb i have that problem
    and from 2.0 and 2.1 version
    i have test it from 3pc's Xp vista and 7
    i dont think that is a hardware error
    because on my previous cluster
    http://www.youtube.com/watch?v=Q2Ym7Q0MooM
    there where no problem and everything was ok
    thanks a lot
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    It's likely that your virtual serial port driver did not install correctly.
    -Can you show a screenshot of your Device Manager with Ports expanded?
    -Do you see your virtual com port under ports, or is it elsewhere in the device manager?
    If it is elsewhere, right-click on it and delete it (with permant removal checkbox if shown). Then unplug it and plug it back in ensuring that you are connected to the internet so the drivers can be automatically downloaded.
  3. herctrap
    herctrap Member
    Ilion / Pylos
    243Coins
    the serial port is OK because i cansend data from a hypper terminal and the cluster responds
    my friend that i gave him the cluster yesterday told me at 3 o'clock in the morning tha he changed the port from 21 to 2 and it worked
    i will check it later
    thanks a lot
  4. tronicgr
    tronicgr
    Hi Herc,
    Try to change he comport settings to Serial Printer... ;-)
    Works for me!
    edit: Here is a link that might help post13868.html#p13868
    Thanos
