F1 2010, X-Sim funny bug
Discussion in 'Archived information' started by aikuo60, Jul 19, 2011.
  1. aikuo60
    aikuo60 New Member
    It's the first time i saw this bug
    I have F1 2010 box version and i change the good line in hardware_settings_config (in my documents/my games/...
    <motion enabled=true ip=127.0.0.1 port=20777 delay=1 extradata=1 />
    i use a online profile for F1 2010 i start X-Sim profiler, sender choose DIRT2 plugin... and nothing, there is no nothing my simulator doesn't move.
    and when i verify the file hardware_settings_config, the line has change like this:
    <motion enabled=true ip=127.0.0.1 port=4377 delay=1 extradata=0 />
    I replace several time (and save) with the good line in hardware_settings_config and several time my hardware_settings_config change, and my simulator never works with F1 2010.
    Someone have a idea with this bug??
  2. egoexpress
    Afair it is due to the autosave function within the game. Try to disable autosave ingame, then change the config file, then enable autosave again.
    regards
  3. abs
    consultant
    Montreal
    784Coins
    3DOF, SCN5
    How did you open the config file ? (software used). I used wordpad , do the changes and then save
    bye
  4. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    If you really are changing the config file under My documents and not under the game folder then make sure it's not set to read only in F1 2010 root folder properties ...
    Is your computer account part of local administrators group?
    Are you using Vista or Win7 ? Did you disabled user account control security ?
    If the file is not saving your changes then you probably have a security issue ...
    Bleco
  5. aikuo60
    aikuo60 New Member
    Well done!! It was the autosave function. Greatttt!! Thanks to all for the differents solutions!!
  6. ronirock
    ronirock New Member
    - 150Coins
    Good morning to you all, i would like to apologize about my english, i'm writting from South America. Sorry if i'm not in the correct forum but i would like to know if codemasters F1 2011 for PC is a x-sim supported game. Thank you very much in advance.
    Ronald C.
  7. abs
    consultant
    Montreal
    784Coins
    3DOF, SCN5
    oh yes it is and works fine. in 3 screens also . try to open a new topic we are in someone else topic . (F1 2011 is still a little buggy right now though.)
    bye , good luck
