Fanatec CS3 Pedals Inverted
Discussion in 'Commercial Simulators and Peripherie' started by Hoddem, Feb 9, 2017.
  1. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,342Coins
    I just got an email from Fanatec showing off the new CS3 pedals with inverted brake and clutch.
    They are kind of steep at $499 USD plus shipping, but I have a set of the the regular CS3 pedals and without testing hydraulic I like them very much.
    No word yet if there will be a conversion kit sold
    more info here (US Website)
    https://www.fanatec.com/us-en/pedals/clubsport-pedals-v3-inverted-usa.html
    CSPV3i-Big_01-1000x666.png CSPV3i-Big_06-1000x666.jpg CSPV3i-Big_04-1000x666.jpg CSPV3i-Big_07-1000x666.jpg CSPV3i-Big_03-1000x666.jpg CSPV3i-Big_02-1000x666.jpg CSPV3i-Big_05-1000x666.jpg
    I do not have any affiliation with Fanatec
  2. RaceRay
    23,862Coins
    Received the same newsletter a few minutes ago.
    A few additional informations about the new ClubSport Pedals V3 Inverted
    • 12bit resolution (4096 values) on all axes
    • contactless hall sensors on the two pedal arms for throttle and brake
    • pressure sensitive brake with custom made 90 kg load cell sensor
    • pre-load screw allows tool-less adjustment of the stiffness and travel of the brake pedal
    • brake sensitivity can be adjusted during gameplay in the wheel tuning menu
    • pedal plates adjustable in horizontal and vertical position, distance, and angle
    • pedal extensions, pre-mounted on clutch and brake and as accessory for the throttle
    • alternative D-shaped pedal plates
    • vibration motors on the gas and brake pedal
    • RJ12 wheel base connection, USB connectivity (allowing operation with any other racing wheel brand as a second device on PC), and handbrake port
  3. SilentChill
    20,557Coins
    Yeah they do look nice but for 599 euros they are way to steep be better off buying some HE's
  4. Hoddem
    Engineer
    Minnesota, USA
    3,342Coins
    No doubt they are expensive, but I see a lot of people inverting fanatec pedals. These should give others ideas on how to do it and hopefully they will release a conversion kit eventually.
    Although looking at the bracket that holds the brake and clutch, it looks way to small to me. I bet there is a ton of side to side flex. hopefully we will get to see some videos eventually.
