Feedback on 2.0
Discussion in 'SimTools DIY Version' started by Vef445, Jan 17, 2017.
  1. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    Hi all,
    I've already received my 2.0 DIY license (thanks for the fast reply!) but before uninstalling and re-configuring the whole thing, I'd like to have your feedback on this new version.
    From what I understand, in my case (basic 2motors 2DOF rig), the configuration should be very similar to v1. I'm actually wondering if I would have any immediate benefits using 2.0?
    I also realised that I'm losing the dash until I decide to buy a pro license...but I might actually do so in case I need to help out again with the Codemaster plugins :p
    Looking forward to hearing from users :)
    147,878Coins
    +10,880 / 54 / -2
    For me SimTools 2.0 is more responsive, it feels like an engine upgrade, generally speaking is a bit more automated and refined to use, will have expanded functionality like transducer support, can support far more axis/forces such as a 6DOF + G-seat and in many ways is designed to be the basis for endless expansion, because everything and anything can be treated as a treated as a plugin.
    The license provision now also extends to commercial use, not just DIY users.
    JRK support is now native.
    @yobuddy is putting in a lot of time and effort to squash bugs.
    All dev and plugin focus will now be on 2.0, with 1.3 to be depreciated in a year.
  3. Vef445
    Denmark
    597Coins
    Hi @noorbeast ,
    I'm quite aware of the different changes in term of licenses...etc, been following that closely, but thanks for the reminders :) What I'm looking for is more around user experience, like when you talk about responsiveness. That's definitely an interesting feedback :)
    I've spent lots of time fine-tuning V1 and I must say that I might need some good reasons to switch now to v2 and start form scratch :)
  4. yobuddy
    49,199Coins
    @Vef445
    Your not starting from scratch thou.
    SimTools 2.0 will be simple for you to setup now!
    The only difference in setup is <Axis1> is now <Axis1a>.
    You will feel the difference for sure!
    But before you remove 1.3 thou, backup this folder.
    C:\Users\(Your User Folder)\AppData\Local\SimTools
    Then if you ever want to go back, simply install 1.3 and replace this folder.
    You won't lose anything!
  5. Vef445
    Denmark
    597Coins
    Thanks @yobuddy , and it's true that I wouldn't take much risk to lose the current setup.
    Well, I guess I just have to give it a go now :)
  6. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Well worth your time to change over to 2.0
    I would say the fidelity is 30 to 40% more for me, and I have not had much time to fine tune!
  7. yobuddy
    49,199Coins
    w00t! :thumbs
