Finally the motors works
Discussion in 'DIY Motion Simulator Projects' started by marco cristopulos, Jun 5, 2021.
  1. marco cristopulos
    marco cristopulos New Member
    139Coins
    Hi
    And thanks all replys to help me.
    Finally works the motors and smc3,....
    What is next to do for get a car mov simulation?
    148,616Coins
    +10,909 / 54 / -2
    If SMC3 works as expected the next step is to download the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then configure the SimTools interface Settings:
    Interface Type - Serial
    ComPort = the Arduino ComPort, you can find it in Windows Device Manager.
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>]
    After that check Output Testing works as expected, this is how SimTools expect axis movement to be configured: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    Next up is patching a game for motion, the fully function plugin for Live For Speed is included with SimTools, but LFS needs to be run in first person mode before patching it for motion, as that generates some required files: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    Finally a motion profile needs to be refined for each game see the tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  3. Boris Furtak
    Boris Furtak Member Gold Contributor
    160Coins
  4. Boris Furtak
    160Coins
    Hi Noorbeast, trust everyone well.... I need some advice.. please ... I have my basic setup .. I'm getting interface between all components... I'm running simtools got the values I needed.. but I'm doing something wrong I'm not getting any sort of feed back to my arduino... while the game is running... could you put me on the right direction pls ... when it comes to what all must run in the background. ... must smc3 also be running...
    148,616Coins
    +10,909 / 54 / -2
    Please see my response here: https://www.xsimulator.net/community/threads/arduino-and-simtool-diy-simulator-f1.16645/#post-222236
