Question Flange coupling for rare spline/gear shaft
Discussion in 'DIY peripherals' started by pupdeg, Apr 13, 2022.
  1. pupdeg
    pupdeg New Member
    9Coins
    I've got an old 130mm hc-sf102x servo with a shaft that measures around 16mm outer diameter with 14 teeth, and I'm trying to work out the best way to make a 70mm flange for it for mounting to a wheel, given I can't find anything off the shelf that matches it.
    3D printing isn't really an option, and I don't trust it for load bearing applications. I was thinking of making a laser cut stack of steel plates, maybe 5-10mm in diameter and held together with locating bolts, with a slightly undersized central cutout that could be filed to fit. I figure this would work out cheaper than a custom machined part, and the whole thing would only need to be about 20-30mm long, so 6 plates at 3 bucks a plate would run me maybe 20 dollars, which is less than I'd pay for a custom machined one-off part.
    Any alternatives or issues I haven't considered? Or anyone encounter this style of shaft before and found an adapter?
  2. sedesa tatasa
    sedesa tatasa Member
    497Coins
