Flight Sim DoF Priorities
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Origamikid, Mar 25, 2015.
  1. Origamikid
    Origamikid New Member
    60Coins
    I'm in the conceptual stage of a new design and I'm curious what this community believes is the ranking of importance. On my sketches right now I have roughly +/- 60 deg roll and +/- 30 deg pitch; I'm trying to see if I can make a compact design that is passable as a normal office chair when not in motion. However I've never owned a motion sim so I don't know where the different "break points" are in tiers of experience.
    Feedback welcome.
  2. bsft
    148,578Coins
    +10,903 / 54 / -2
  4. Origamikid
    60Coins
    Hmm, I'm going for a similar movement to a joyrider (center of rotation above CG). I'm not sure what range I need but it's intended for space/combat flight sims so my intuition was to get the roll somewhat strong. If I could afford a continuous rotation I'd honestly be trying to do that! If I went to 3 DoF what is next in importance?
    148,578Coins
    +10,903 / 54 / -2
    The 3DOF priority for a flight sim would be heave.
  6. Origamikid
    60Coins
    Thanks for the help. Heave seems very tricky on a budget, I might just have to leave it out for version 1. I also think I mis-estimated and could get about 30 deg pitch total, not each direction so hopefully that's enough.
    148,578Coins
    +10,903 / 54 / -2
  8. Origamikid
    60Coins
    Do you think there is any special considerations that could be made to optimize it as a space sim? Besides of course putting it on a gryo platform to simulate 0 g which is WAY beyond my budget (space and $).
    148,578Coins
    +10,903 / 54 / -2
    For a space sim the most important thing is how the forces are done in the plugin. As an example @value1 has done a great job of the Elite Dangerous plugin.
    I think VR is an obvious choice for a space sim.
    Design wise consider things that can be made to give additional sustained motion cues, like the race harness, as that and something like my quasi surge table together can simulate a sustained 'burn' type effect for a space sim.
  10. Origamikid
    60Coins
    Do you have a link for the quasi surge? Not quite sure what that would be.
    148,578Coins
    +10,903 / 54 / -2
