Croccy
Flyinside Flight Simulator 1.0
Simtools plugin for Flyinside Flight Simulator
  1. Croccy
    Croccy Member
    System Admin
    Ilfracombe
    423Coins
    Croccy submitted a new resource:
    Flyinside Flight Simulator - Simtools plugin for Flyinside Flight Simulator
    • Winner Winner x 3
  2. Croccy
    Croccy Member
    System Admin
    Ilfracombe
    423Coins
    Have posted version 1.0 of the plugin. Can be found in the Game Plugins section of this site.
  3. SilentChill
    20,557Coins
    Nice work , I've finally got round to trying out now Flyinside had some decent updates.
    I've found one major issue , when on the ground moving any movement to turn the airplane results in crazy movements in yaw sway and surge little sharp movement throwing the rig everywhere anyway you could look into that as its unusable on the ground unless your going in a straight line.
    In the air it all works great, I think a Yaw acceleration would be great as an Extra also Pitch and Roll if you can do it.
    Thanks again though great work :)
  4. volker metzger
    volker metzger New Member
    - 725Coins
    Hi Croccy, thank you for your work, it is possible to release the source codes ?, i will try and enhance it
  5. abbas
    abbas New Member
    retraite
    france34
    - 128Coins
    hello @Croccy I have a problem with flyinside fs and simtools the patch does not work it asks me for the flyinside directory but it cannot find flyinside .exe so the patch does not work how to do it thanks in advance
    147,956Coins
    +10,883 / 54 / -2
    It looks like @Croccy has not been active since January 2021, so it is hard to say when you will get a response, so perhaps @SilentChill may be able to advise instead.
