Force Sender Plugin Question
Discussion in 'Force-Sender & Plugins' started by motaro38, Aug 23, 2011.
  1. motaro38
    motaro38 New Member
    Can someone explain to me why when I choose 'Open plugin-assistant' and then the '...' next to the game name to find the plugin file, it displays next to Files of type: .fsd, when all the files in the X-Sim plugins folder are .dll?
  2. eaorobbie
    20,432Coins
    ok mate yes a little confussing.First you need to open the force sender and set up the ip address, force feedback device that you are using then find and enter the game address plus any other parameters you want to run when game starts.
    Then the click file save, then you have the .fsd file needed to plug into plugin assistant.
    Basiclly the .fsd file is the profile sender's setting that you want loaded for that game, save a different one for each game you want to set up in sender.
    :hi:
  3. hooshang
    hooshang Active Member
    285Coins
    hello earobbie
    it was also fruitfull to me
    thank you freind
    hooshang
