FSX Plugin!!!!!!!!!! help
Discussion in 'Force-Sender & Plugins' started by leandroter7, Nov 4, 2009.
  1. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    I try use X-Sim with Flight Simulator X, but i cannot make it run, i use FS plugin, nut nothings happens. Please help!!!
  2. scottlolo89
    scottlolo89 New Member
    france
    348Coins
    fsuipc in programme fil in fsx in modull
    sender select plugin msflight 2
    profiler select in maths
    lateral acceleration for x roll
    vertical acceleration for y pitch
    sorry i am french
    fscuipc serves has comuniquer with force to sender
  3. toktiny
    toktiny Member
    - 20Coins
    For Scottlolo89
    Have you got a Profile for FSX ? If so could you download it into the forum ?
    Many thanks
  4. scottlolo89
    france
    348Coins
    yes i have a good maths pluning for fsx
    in the real position for plane the effect tilt horizon in colaboration in flightsafety simulator its my friend
    i post the profil friday
  5. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    how can i make it work? plis
  6. toktiny
    toktiny Member
    - 20Coins
  7. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    I follow the CXC steps, but i no have make it work properly. There's some plug in of x-sim to put inside of FSX to make it wortk?????
  8. toktiny
    toktiny Member
    - 20Coins
    Here are some basic directions for you ;
    *Launch Force Profiler
    *Load your selected profile. (Which I assume you have )
    *Click Interface Settings
    *Click on the SCN5 plugin and set the Speed to 3000 and Acceleration to 10 (Or whatever speed and acceleration you find most suitable for your setup ). I find this a middle of the road setting for FSX but it will depend on which plane you choose to fly. The smaller and slower the plane the lower the settings.
    *Select the “MSFlightSim2” Plugin in Force Sender (A new window will open when you do so which we will call the FSUIPC window)
    *In this new window yiou may add any “Effects” from FSX that may not be included allready for you by default. If you should use this facility add the values and details of your required effect into the appropriate columns .
    *Click Update user values in FSUIPC plugin. This will transfer any new info. into Force Sender which in turn will be transferred into X-Sim.
    *Leave this window open, go back to Force Sender and click Try send data
    *Go back to Force Profiler and Click Start
    *Now launch FSX
    Hope this is of some help to you.
    Regards
    Toni
