Futaba servo control using Pololu controller
Discussion in 'Force-Profiler Simulator Control' started by jacoaj, Oct 21, 2009.
  1. jacoaj
    jacoaj New Member
    - 24Coins
    Hey there fellow gamers well I am needing some assisstance with controlling my 2 futaba servos using a Pololu controller in Mini SSC II mode
    I'm using 4 axis in the profiler to start with.
    1Xsteering(a01) and,
    2X for acceleration(a02 and a03), one of which is inversed so 1 servo runs in reverse to the other
    I am having problems stringing the USO packet data, for example
    for steering use = ~255~~0~~a01~~255~~1~~a01~ which seems to work
    for acceleration = ~255~~0~~a02~~255~~1~~a03~
    but when i put them together as a single string in the USO parser only one of them will work and the servos seem a little scrambled.
    Am I approaching this the right way or not?? I havent even got the brake condition yet in which both servos will have to move in opposite directions to the acceleration to push the sim up for braking.
    Any suggestions would be greatly appreciated, cheers
    jacoaj
  2. jacoaj
    jacoaj New Member
    - 24Coins
    Thanks sirnoname for your interest in my project i just put them together. do i need more axis or not
    currently a01 = steering,a02 = acceleration servo #0 and a03 = acceleration servo#1(opposite direction)
    ~255~~0~~a01~~255~~1~~a01~~255~~0~~a02~~255~~1~~a03~
    then would i need to add two more axis for brake condition a04 and a05.
    I tried to have more than one input in the math section under g-force for the same axis but it only seems to operate the last input in the list, ie the one that the calibration offset is set to.
    cheers jacoaj.
  3. jacoaj
    jacoaj New Member
    - 24Coins
    thanks for that i will try soon will let u know the progress, cheers jacoaj.
  4. jacoaj
    jacoaj New Member
    - 24Coins
    looks like same problem, here is the latest using 5 axis and the 2 servos that will drive two window motors for the sim. just using a logitech driving force with steer,accel and brake.
    acceleration1 servo#1 a01
    acceleration2(counterclock) servo#2 a02
    brake1 servo#1 a03
    brake2(counterclock) servo#2 a04
    steer servos# 1 and 2 a05
    and the string
    ~255~~1~~a01~~13~~13~~255~~2~~a02~~13~~13~~255~~1~~a03~~13~~13~~255~~2~~a04~~13~~13~~255~~1~~a05~~13~~13~~255~~2~~a05~
    if I try each string separately, for accel,brake and steer, it works, combine then and the servos act scrambled.
    jacoaj.
