game dont give me feedback
Discussion in 'Yoda - ForceFeedback Scanner' started by merancio, Jul 21, 2008.
  1. merancio
    merancio New Member
    i have a problem with force sender. i conect yoda with ip address of the other computer in a remote yoda and conect force sender with force profile but when i have to play game in force sender the game can not open and close the windows of yoda and force sender and lose the conection.
    i´m using fligh simulator 2004 and joystick logitech attack 3, and i dont if this joystick have a feedback.
  2. egoexpress
    Re: tama
    There is a bug with the play game button since decades. Sirnoname should better have removed it perhaps...
    Besides that. All MS Flight sim titles work with a Force-Sender plugin.
    You dont need Yoda at all for FS, as Yoda captures ForceFeedback data, which are not provided in MS FS.
    Copy the FS plugin out of the X-Sim Force sender directory to the MS FS/modules directory, and then select the FS plugin in the Force-Sender.
    Here is a little tutorial. Sorry, by the lack of volunteers it isnt translated to english yet. But looking at the pics will help...
    http://www.x-simulator.de/de/force-send ... suipc.html
    Regards
    Christian
  3. merancio
    merancio New Member
    Re: tama
    i copy the fsuipc.fsi and fsuipc-helper to the folder modules of de fligth simulator.
    when i have to open the game in a force sender close the windows if i open the outside the game dont gime me feedback.
  4. egoexpress
    you have to acitvate fsuipc plugin in the game the first time.
    As far as I remember, you have to pause the game, or press alt in the game, and then you see a bar in the upper corner, where you can select a tab named modules. There you can activate the FSUIPC plugin.
    I hope this info is right, as I hardly can remember.
    If that does not help, then send Renoboss a pm. I think he is able to help you with MS FS.
    Btw: Have you installed MS FS to C:?
    Regards
    Christian
