Resolved Game Engine crashes with Dirt 3
Discussion in 'SimTools DIY Version' started by Oms, May 26, 2019.
  1. Oms
    Oms known as "Doc6dof"
    France Colomiers
    - 173Coins
    DC motor, AC motor, Arduino, Motion platform
    Hello everybody,
    My OS is Win10 64 bits. No pb with Rfactor 1, Xplane 10, etc... but pb with Dirt 3.
    Do you have faced this kind of problem: after having patched with Dirt3_GamePlugin.2.0.0.1 (the directory Document/My games/Dirt 3), Game Engine crashes when I select Dirt 3 in game list. The error message is:
    Unhandled exception has occurred in your application...
    thank you in advance
  2. yobuddy
    49,199Coins
    Please try this,
    Unpatch dirt3, then run a race and make sure it both works, but also complete the race so it makes the fire we need to patch.
    Then patch the game with GameManger, but do it in your Documents/My Games folder (as you are on a 64bit machine)
    Then give it another try.
    Take care!
  3. Oms
    France Colomiers
    - 173Coins
    Thanks Yobuddy
    It is better. The new pb is that te amplitudes are very small (a few mm !!), even if I parameter at maximum surge/sway/heave, so at 150% (I have a diy 3 dof seat mover). If I did the same with that with rfactor, my motors would explode !!!
    Do you have an idea ?
  4. Oms
    France Colomiers
    - 173Coins
    Hello again
    I did some tests with pitch and roll at the max (150%), same behaviours than with surge and sway = actuators move just a little bit...
    do you have an idea of the root cause ?
    see you
    147,878Coins
    +10,880 / 54 / -2
  6. Oms
    France Colomiers
    - 173Coins
    ooh I was hurry to play so I did not... I try that this evening, thanks
  7. Oms
    France Colomiers
    - 173Coins
    FANTASTIC that is impressive, thank you for you help
    GREAT SCOTT !!!
