Game engine crashing
Discussion in 'SimTools DIY Version' started by jem45472, May 14, 2014.
  1. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    I have been having some problems with the game engine. Windows7 64bit 4gig ram.
    While playing game cpu about 70%, ram 50%
    Everything goes ok, then simtools will stop controlling one motor. It just locks up 1 motor and game engine crash. Go to task manager and says simtools running even after closed and need to restart computer to stop simtools from running.
    Here is error report.
    Problem Event Name: CLR20r3
    Problem Signature 01: simtools_gameengine.exe
    Problem Signature 02: 0.1.2.0
    Problem Signature 03: 52e88fe0
    Problem Signature 04: System
    Problem Signature 05: 4.0.0.0
    Problem Signature 06: 4ba1dff4
    Problem Signature 07: 404a
    Problem Signature 08: ec
    Problem Signature 09: System.IO.IOException
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Any help would be greatly appreciated, thanks.
  2. jem45472
    Buffalo NY
    97Coins
    Update
    Seems to be ok now.
    Appears it may from my cheap usb cables running to jrk.
    I have problems now and then with one of them, I will have to spend a little and get some decent cables.
  3. jem45472
    Buffalo NY
    97Coins
    Crash again!
  4. yobuddy
    49,198Coins
    Sounds to me like your motor controller is disconnecting from your PC?
    "System.IO.IOException"
  5. jem45472
    Buffalo NY
    97Coins
    Yes I believe I need new USB cables.Thanks.
  6. bsft
    Did you check, when the game engine crashes, to see if the motor still runs in JRK utility program?
  7. jem45472
    Buffalo NY
    97Coins
    [QUOTE="bsft, post: 55958, member: 4876"Did you check, when the game engine crashes, to see if the motor still runs in JRK utility program?[/QUOTE]
    In jrk, one motor on and the other off. Didnt test for motion. Restart PC and all is well.
  8. bsft
    use a bigger hammer next time
