Gamedash and Arduino Mega 2560 w/ TM1638
Discussion in 'Electronic and hardware generally' started by Archie, Apr 8, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    So, I dusted off my Arduino Mega 2560 after I got a TM1638 module from DX this week.
    The code I got from @soraz's post is set for the NANO. Where the Digital pins are D3 to D5, can I just modify the TM1638.h to map to 3 Digital pins on the Arduino Mega? (Which go from D22 to D31?)
    Tagging you @eaorobbie as I have seen a few posts where you have had input on this, so you might know :)
    Thanks,
    Archie.
  2. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    according mapping reported here -->> http://forum.arduino.cc/index.php?topic=45329.0
    i think you can modify tm1638.h
    #define PB6 6 //D12
    #define PB5 5 //D11
    #define PB4 4 //D10
    #define TM_OUT PORTB
    #define TM_IN PINB
    #define TM_DDR DDRB
    #define TM_BIT_STB _BV(PB4)
    #define TM_BIT_CLK _BV(PB5)
    #define TM_BIT_DAT _BV(PB6)
    or
    #define PA2 2 //D24
    #define PA1 1 //D23
    #define PA0 0 //D22
    #define TM_OUT PORTA
    #define TM_IN PINA
    #define TM_DDR DDRA
    #define TM_BIT_STB _BV(PA0)
    #define TM_BIT_CLK _BV(PA1)
    #define TM_BIT_DAT _BV(PA2)
  3. bsft
    Rob is at work, I have let him know via email you need assistance
  4. eaorobbie
    20,487Coins
    Don't see an issue just change the line that sets the Pins for the TM1638 , easy as.
  5. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    my project use an alternative fast library for TM1638 where pins are coded in library.
  6. Archie
    Wollongong, NSW, AU
    3,797Coins
    Figured that was the case. Will give it a go over the weekend. Thanks guys :)
  7. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    It's working.
