Gearshift
Discussion in 'Suggestions for improvements - Oudated' started by Renoboss, Nov 19, 2006.
  1. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Hello Sirnoname,
    Did you read your PM?
    Today i gave up on rFactor!!
    I switched my potis to 10Kohm types , but no improvements noticed on the movements.
    Later on started on GTR2. The plugin and the outsim.exe work fine.
    On #21 i found the gears. Inserted geareffect on 1 and later for 2 and 3.
    It works! but only in the wrong direction (down on y-axe).
    Is it possible for you to make or program an selectable option to enter movementdirection (invert) in the effectbox.
    Does GTR2 has a ingame x-axe ?
  2. Renoboss
    297Coins
    2DOF, SCN5
    >I know, but my first post in this topic was 19 nov. so we just passed eachother!
    >I implemented an action on the values 1, 2 , 3 ,4 and 5. so everytime i shift the Geareffect is played. The problem is that the Geareffect is lifting
    the chair first (on change) and then lowers the chair again.(on acceleration)
    Like in a real car when you change gears the front will drop and when you accelerate the front will lift again.
    That's way i ask for an invert (effekt) option.
    Another possibility is to insert a freely programmable option?
    Off topic:
    Currently i'm busy designing a Frex-style setup to be used with air-actuators and your software.!!
