Got a question for you Flightsim folks
Discussion in 'DIY Motion Simulator Projects' started by raflyer, Jan 12, 2012.
  1. raflyer
    raflyer New Member
    I am having a hard time with this set-up on my new sim I am building. Here is the deal, the motion base system I am using has pitch, roll, and yaw. The Yaw/heading axis spins the base 360 degrees.
    I am not sure whether to use the yaw or just make it a 2-DOF sim.
    Pro's with:
    Accurate butt feeling/flight feel when using rudder, like slipping and uncoordinated turns etc
    Heading gauge and compass read and react 100% correctly and easy to interface
    Pro's w/o:
    Much easier to set-up because power supplies, PC, and Display can all be separate
    Spare motor in case one of the others break
    Can use PJ for a large front display.
    Con's
    Everything must be attached to sim like PC, power supply's etc , Space is very limited
    Can't use projector
    Have to mount 32 TV to front of sim
    Heading Indicator and compass much harder to interface
    I am really struggling to finalize this question and am looking for input. Good, bad, ugly don't care
    What would you do?
    Thanks,
    Rob
  2. bsft
