value1
GRID (2019) Plugin 2.0.0.2
SimTools plugin for GRID (2019)
  1. value1
    14,751Coins
    GRID (2019) Plugin - SimTools plugin for GRID (2019)
    • Winner Winner x 4
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    635Coins
    ANYONES WITH GAME VIBE WORKS with this plugin?
    i try rpm ( this one comes with ) but nothings happen maybe because
    rpm isnt on speed position. Anyway, i try to create vibe but none of effects appears
    on game vibe menu.
  3. highi
    highi Highi Racing Simulator 17 Gold Contributor
    8162 Steinmaur, Switzerland
    133Coins
    3DOF, SCN6, Motion platform
    Thank you for the quick provision of the plugin. in general, the strength of the effects is very weak. In addition, the traction loss effect is not adjustable. i.e. When you press the throttle, traction goes off without the car breaking out. I tested many settings unfortunately without success.
  4. value1
    14,751Coins
    Thanks for the feedback!
    Try adjusting the MaxMin values in Tuning Center. The lower the MaxMin values the stronger the effects.
    The traction loss could be faulty. I'll check later.
  5. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    I played a race, the game saved.
    I installed the plugin and Patch Game.
    Game Running activates but has no moves. Tunning center also does not receive data.
    Does anyone know what should be done?
  6. Leandro Kemp
    Brasil
    - 10Coins
    Game Running
  7. paulopsx2
    brasil
    635Coins
    Yeap. Grid only Works with motion on dx2.exe ! This game provide 2 .exe The ones within dx12 and grid.exe for dx11. Just Double check in grid_dx12.exe
  8. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    ok thanks for the plugin but doesnt seem to work for me any setup guide?
  9. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    i can see only one .exe
  10. BlazinH
    16,613Coins
    Its been years now but I recall Grid's motion being spongy and arcade like to begin with when compared to some other titles.
  11. value1
    14,751Coins
  12. BlazinH
    16,613Coins
    :oops: I didn't know they were rebooting the series. :thumbs
  13. paulopsx2
    brasil
    635Coins
    my folder have 2. dx12_grid.exe
  14. Newgun
    Newgun Member Gold Contributor
    United States
    77Coins
    AC motor, 4DOF
    Hello, I'm still having issues with Traction Loss.
    In Version 2.0.0.1 the TL would move only one way and it also moved during braking (Surge).
    In Version 2.0.0.2 the TL would move the opposite direction and it also moved in that same direction during braking (Surge).
  15. Newgun
    United States
    77Coins
    AC motor, 4DOF
    Ok, after the recent update for Grid 2019, I removed patch, ran a race, closed the game, re-patched via the Plugin Updater, and now all movements are working great. Thanks for the great plugin, @value1
    Now if Codemaster can allow for more FOV and HUD adjustment it would be great.
  16. frodus17
    frodus17 New Member
    - 31Coins
    I'm having issues getting it to work. It cocks to one side, and then stops responding completely at some point. Using the Dx12 exe, removed patch, ran game, re patched. Nothing works. I got it to work one time, but it has stopped working. Sometimes simtools crashes.
    Step by step, how can I start over from scratch and get this working? I like the game, but I'd like to use motion.
  17. frodus17
    frodus17 New Member
    - 31Coins
    Resolved. I had it forwarding packets to 4123 in Simhub. I use Simhub for shakers and forgot I had that forwarding. Working now.
  18. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    37Coins
    delete the save run 1st time with everything installed and check anti virus by omitting simtools and steam game files
  19. paulopsx2
    brasil
    635Coins
    maybe a new plugin for grid legends? tks
  20. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    Michigan USA
    252Coins
    3DOF, AC motor, SCN6
    can someone please tell me how to patch this game through Steam. I select the general Grid folder in my steam library folder but it tells me that's not a valid path.
