GRID crashing in windows 7 - sometimes
Discussion in 'GRID' started by bsft, Oct 1, 2011.
  1. bsft
    Hello, I am running windows 7 professional, x-sim beta 21013, all current drivers, even updated game patch to 1.3, but the game still crashes going into a race, mostly the japanese races. Dunno why, I have tried various compatibilty settings to no avail.
    Any ideas?
    Thanks, David.
  2. BartS
    BartS Member
    417Coins
    if it crashes without xsim running try you graphics driver also lower settings to test
  3. bsft
    Thanks, I will give it a try. I hope its not a graphics driver issue, I cannot go back to an older driver as the 2 x GTX560 Ti in sli will not work.
  4. bsft
    Nope , that didnt work either. The game either doesnt load japanese races or crashes after the race has finished. All other games - USA and Europe work fine. I have re-installed it 3 times. Even tried x-sim beta 2.08, and tried the game on its own. I am running the latest version of the logitech driving force gt driver being 5.10.
    Any ideas?
  5. bsft
    Am I the only silly sod trying to run GRID under windows 7 64 bit?
  6. bsft
    GRID is crashing randomly in Win 7 64 bit
    Can any one tell me why GRID is crashing randomly in Win 7 64 bit! I have tried everything. I have the boxed version, tried patches, disable sli, disable anti virus, compatibility changes, re-installed it 3 times, read through MANY forums....NOTHING!!!!
    Am I the only one having a murphys law with this game?!?!?!?
  7. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Re: Grid vs 8 cores cpu issues
    Are you running a 8 cores processor?
    Grid is not compatible with 8 cores cpus... It was designed for no more then 4 ....
    heres the fix :
    Open hardware_settings_restrictions.xml with notepad ... find workerMap8Core.xml, and change the 8 to a 4, then just save and play.
    There are multiple topics all over internet about it ... I think it's pretty much it but I did it a long time ago ... you might have to change other values as well in the same file, search the web for additionnal details ... it worked for me ...
    Try it if you are using a 8 cores cpu ...
    Bleco
  8. bsft
    Thanks but no, I am still using the same AMD 965 QUAD core cpu, just a new motherboard and now 2 GPU's. Yes I have tried with SLI disabled as well. Yes I have tried the 8 core fix anyway despite having 4 cores. Do you by chance have a copy of the hardware restrictions file you can share with me, in case I am doing something wrong?
    Thanks, David.
  9. bleco
    Montréal, Canada
    258Coins
    Hi David,
    I don't have the game installed anymore ... but I have a copy somewhere, I will see what I can do.
    Bleco
  10. bsft
    Thanks Bleco, just to confuse things further, on my pc , it only crashes before and or after a j-speed event, either race day and or career.
    Ergh!
  11. bsft
    Ok, just spent 2 hours playing GRID, definitely only crashes after completing a j-speed event, either race day, driver offer, or career. All other races fine.
    This is a weird one!
    ;P
  12. bleco
    Montréal, Canada
    258Coins
    There seem to be known issues with freezing vs motion enabled ...
    http://www.x-simulator.de/wiki/Racedriver_Grid
    The game has some bug in the network section, so after a network game with motion enabled is set to true, the game freezes in a black screen after each race. You can press the space or return key to get back to the desktop again.
    Bleco
  13. bsft
    Thanks for that help. That sounds like the problem, obviously not much I can do then, although it explains the random crashes, usually leaving the quit, and going to black screen, that was under win xp 32 bit.
    Now it crashes after a j-speed event, dunno about that one!
    Still thanks for the help, good thing I do not play online or I would be stuffed :uups: , I will just have to tolerate it. :cheers:
