GTR2 Plugin bugs, and help needed!
Discussion in 'Force-Sender & Plugins' started by Frakk, Jan 3, 2010.
  1. Frakk
    Frakk Active Member
    328Coins
    First, I noticed a little bug with the GTR2 plugin (possibly the bug is in Profiler?) and the Gear Indicator numbers. The number I have in the Input section of the Profiler go from -1(R) 0(N) 1(1) 2(2) ..... , but my USO output won't go below 1 (32768). (R) and (N) are both show up as 1, Gear 1 is 1, Gear 2 is 2 (32769).
    Anyone know why this is, or any way of fixing it?
    Also I would need some explaination of the rotational data that comes out from the plugin, Pitch, Yaw, Roll.
    I noticed that the Yaw data shows Altitude, but the other two I cannot seem to figure out.
    How can I make real motion out of these? If the numbers show Altitude, Direction, and such data, do I have to take the derivatives for the rate of change?
    Thanks,
