help I do not know what to do Arduino + sabertooth
Discussion in 'DIY Motion Simulator Projects' started by dualclick76, Jul 12, 2015.
  1. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    asking for help from guru sim, I do not know what to do I have a lot of confusion in my head. you could be so kind as to show me all the steps of the various configurations? Arduino? sabertooth? simtools? thanks again for your kind and caring patience
    148,616Coins
    +10,909 / 54 / -2
  3. dualclick76
    italia
    11Coins
    thanks noorbeast I looked but I could not, I do not know what to do with the configuration of the sabertooth Arduino
  4. dualclick76
    italia
    11Coins
    I looked but I could not, I do not know what to do on the configuration of the sabertooth to Arduino via USB with the program or you have to describe all the links in the post as I know only that there is no movement
  5. dualclick76
    italia
    11Coins
    They are demoralized
    148,616Coins
    +10,909 / 54 / -2
  7. dualclick76
    italia
    11Coins
    I did not understand whether the configuration of the sabertooth is to be done with the enclosed software Describe, if it has to be connected with usb words need to be followed as a kid on the first day of school
    148,616Coins
    +10,909 / 54 / -2
    This covers the basics of installing the Arduino IDE and testing it if you have not already done so: https://learn.sparkfun.com/tutorials/installing-arduino-ide
    The code needs to be installed on the Arduino: http://www.xsimulator.net/community...ified-serial-working.136/download?version=296
    Yes the Arduino is connected via USB.
    And all other wiring and DPI switch positions are as per the picture: http://www.xsimulator.net/community...bertooth-using-simplified-serial-working.136/
    @Wanegain kindly created the code and directions so can likely assist if there are issues.
  9. zigzag49
    zigzag49 Active Member
    713Coins
    Hello You want to build or what exactly it is already done and you want to configure?
    what type of sabertooth 2x25, 2x32?
    arduino uno?
  10. dualclick76
    italia
    11Coins
    the simulator is already built to work with Arduino Leonardo 12v and monster moto shield and two engines Smolka 24v, then I wanted to run engines to 24v using Arduino + 2x32 sabertooth and supply 24v. I state that I have followed step by step what is written by winegain. but I do not understand how to configure the sabertooth, if the sabertooth must be connected to the PC with USB and use the program provided by the manufacturer. the software provided "describe"
  11. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
  12. dualclick76
    italia
    11Coins
    Thanks poul I took a look but I do not work, what can I do tests to see what is the problem?
  13. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Is everything set up but the motors do not move?
    If so then it's likely the DIP switches, mine had that problem. It could also be the comm speeds, they need to be different.
    The following was advice from Wanegain...
    - In simtools, the speed must be 9600
    - In Sabertooth 2x32 the speed must be 115200
    - On sabertooth switches 1 and 2 must be OFF.
  14. dualclick76
    italia
    11Coins
    It is all set up and nothing moves'll try to do what you told me and let you know meanwhile thanks
  15. dualclick76
    italia
    11Coins
    poul the two resistors I have to connect?
  16. zigzag49
    713Coins
    Yes branch resistances on p1 and p2 + b connected to the sabertooth.
  17. zigzag49
    713Coins
    Have you taken the XPID_SimTools1_23_2x32_serial code:
    -Set also your com port in device manager
    -in interface settings: adjust to 9600 baud
    output interface = XL <Axis1> CXR <Axis2> C 10ms
    shutdown output = 10ms XEOOC
    Arduino connection: A0 motor potentiometer 1
    A1 motor potentiometer 2
    pin 8 / S1 of the sabertooth
    gnd Arduino / 0V sabertooth
    Sabertooth course switch off 1 and 2
    As tu pris le code XPID_SimTools1_23_2x32_serial :
    -régler aussi ton port com dans gestionnaire périphérique
    -dans interface settings : regler a 9600 baud
    interface output = XL<Axis1>CXR<Axis2>C 10ms
    shutdown output = XEOOC 10ms
    connection arduino : A0 potentiomètre moteur 1
    A1 potentiomètre moteur 2
    pin 8 / S1 de la sabertooth
    gnd arduino / 0V sabertooth
    Sabertooth switch bien sur off 1 et 2
  18. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Yes you need them like this
  19. BlazinH
    16,622Coins
    @dualclick76, You do not need to use Describe software to use a Sabertooth in simple serial mode unless you use the 2x32 sabertooth. The link provided by noorbeast http://www.xsimulator.net/community/marketplace/arduino-code-2-dof-for-sabertooth-using-simplified-serial-working.136/ is all you should need to get up and running. Setting the dip switches on your Sabertooth as shown in the link sets the sabertooth to simple serial mode @ 38400 baud. The arduino will then communicate with it at that rate. In order to connect you arduino to Simtools, in the game engine interface settings, set “ComPort” to the port your arduino was assigned on your computer. Then use the rest of the settings as the picture of the game engine shows in the link. Assuming you have downloaded all the code and connected your pots and other wiring correctly to your arduino, you should now be good to go!
    Note: You must also install the sabertooth libraries on your arduino for this code to work as written.
    Ps. Let me know if you are using a Sabertooth 2x32 and I’ll explain what you need to do to get it working.
  20. bsft
    Use JRKS instead
