Request (Feature) Help! Plugin for Overload - got implementation by the developers !!!
Discussion in 'SimTools Plugins' started by sci666, May 15, 2024.
  1. sci666
    sci666 Active Member Gold Contributor
    1,146Coins
    Hello there, i need support from you guys !
    for the Game Overload - a VR Shooter game like "Descent" from the 90s !!!!
    https://store.steampowered.com/app/448850/
    i get in touch with the developers to implement telemetry output and what should i say . they did it :)
    heres the answer from one of the DEVs:
    Quote:
    "i made a small version that should give the telemetry for everything but gforces.
    i have no way of testing it though so let me know if it works.
    to install it you need olmod:
    1. https://olmod.overloadmaps.com/
    2. go to the olmod folder and replace its GameMod.dll with this file
      https://uploadnow.io/f/tv1GGxS , if that upload platform is sketchy i can share it over discord
    If it worked you should see TELEMETRY in the top right corner of the main menu
    it sends to 127.0.0.1:4123"
    can somebody how knows to create plugins check this and make one ?
    iam also willing to provide the voluntary choosen one a Steam key for it ! :)
    147,009Coins
    +10,845 / 53 / -2
    I am flagging this for @yobuddy, but am not sure what spare time he has at the moment.
  3. sci666
    1,146Coins
    that would be awesome !
  4. yobuddy
    48,790Coins
    We could take a stab at it for sure. Any idea on what gets sent to 127.0.0.1:4123? Like is it a string output, or a structure. Any extra info on this could be helpful.
    It looks like the game does not require VR, so i will run it in desktop mode for testing. In this case I will only need the 'GameMod.dll' file correct? I doesn't look like a demo for the game is available, so if you have a steam key, that would be very appreciated.
    The game plugin may be a bit limited without GForces, but we can always update the plugin when they are available.
  5. egetaskent
    egetaskent New Member
    18Coins
    I just talked to the dev and he said this:
    "the format of what it sends is a string of floats separated by commas
    "{0},{1},{2},{3},{4},{5},{6},{7},{8}"
    the order should be:
    Roll, // angles in degrees (-180 to 180)
    Pitch, // angles in degrees (-180 to 180)
    Yaw, // angles in degrees (-180 to 180)
    Heave, // in (rad/sec)
    Sway, // in (rad/sec)
    Surge, // in (rad/sec)
    Gforce.x, // currently just returns 0 till i find a way to calculate a meaningful value Gforce.y, Gforce.z"
  6. sci666
    1,146Coins
    ?????? i thought this is was the plugin does ..... translate the output from the game in a simtools usable format ?
    please tell us complete informations, to who do you speak ? and what do you tell to him. makes no sense to do uncoordinated requests to somebody ?!
  7. egetaskent
    18Coins
    What are you talking about? We talked to the same dev "luponix". I was talking to him on discord and I forwarded yobuddys question and posted his answer...
  8. sci666
    1,146Coins
    yes but why do you it??? as a new user - because i startet the request and the devs mailed and talked with me ... why this confusion ???! maybe we should invite another 100persons who mail the devs and yobuddy to make the chaos complete ;D ?!
  9. egetaskent
    18Coins
    Chill buddy what confusion? This is a forum I bet yobuddy can handle someone else answering the question lol. You made the post on overload steam community last December and I messaged as well 4 days ago and 2 days ago the telemetry output got done. Literally 2 days after I messaged telemetry output got done so I've been following up with it I already talked to another dev for a bass shaker app. If u didnt make this post I would've made it the same day lol. But anyways bud you got it here I'll leave you to it you are the man for the job
