[HELP] Servo arm or servo horn or a lever (19mm internal diameter)
Discussion in 'Electronic and hardware generally' started by Pit, Jun 25, 2015.
  1. Pit
    30,463Coins
    Hi all I am looking for a servo arm up to 10cm length, or a lever, a crank etc. which has a internal diameter of 19mm. The axle end is a 10 teeth. If someone knows any sources f.eg. on ebay...thanks!
