High Immersion D-Mover Motion simulator with Traction Loss
Discussion in 'Commercial Simulators and Peripherie' started by Frank1999, May 2, 2024.
  1. Frank1999
    Frank1999 New Member Gold Contributor
    45Coins
    4DOF
    Hi All,
    I am glad to introduce you our new motion simulator D-Mover H4, compatible for Simtool 3.0.
    How is D-Mover different?
    1. Self-developed drive control integrated electric cylinder, The actuator parameter:
    Stroke: 270mm(10.5Inches)
    Speed: 250mm/s(Rated)
    Loading capacity: Max. 100KG(Adaptive to loading)
    Max Acceleration : 2G
    Input voltage: 48V DC.
    Use special low voltage DC servo motor, High Dynamic Response. The actuator adopts a drive and control integrated design, and the installation interface is reserved to facilitate the upgrade of the 6-DOF platform
    2. The system is Compact 4DOF design, could be expanded to six-axis 6DOF platform easily.
    Occupying Area: 1.5mx1.2m
    3. Use DC 48V safety voltage with compact power box. See the below:
    Power box size:30*16*12.5cm
    Power supply:1500W
    Input voltage: AC110/220V(depend on the buyer)
    Output voltage: DC 48V (The International Electrotechnical Commission (IEC) stipulates that the safe voltage limit value is 50 DC volts).
    Number of supported axes:6
    P.S.(It's only a power distributor, no need extra drive controller equipment, our driver controller is integrated to the actuator).
    4. Turn key USB kit, easy plug & play
    This is a plug & play kit, USB connect, no additional hardware or DIY is needed. Very simple wiring(Possibly the most simple on the market), all you need is plug in, everyone can do it.
    5. Due to our speed and position double-loop control tech, this 4DOF system bring us very good performance and immersion. Adopting advanced CANBUS communication mode, Synchronization is also very good, almost no latency(<4ms). Theoretically, it can support synchronous motion of up to 255 axes:).
    6. Affordable low price with high quality
  2. Frank1999
    45Coins
    4DOF
    Our D-Mover H4 Motion simulator is compatible for the latest Simtool 3.x, bring you awesome immersion, simplest use and affordable price. Please see the real running video:
