How can I make the SENDER start without a game controller?
Discussion in 'Force-Sender & Plugins' started by phebbler, Jan 16, 2009.
  1. phebbler
    phebbler New Member
    My Question:
    Is there some way to make the sender start even if there is no game controller present?
    My Reason:
    I am using the force injector to extract telemetry data to run my motion simulator that is dedicated to nolimits roller coaster program exclusively. I don't intend to play any other games using this simulator.
    My problem is that a game controller is required for the SENDER program to start. I am using a VM110 USB interface as my motion controller. For some reason the VM110 is not recognized while a game controller is attached unless it is plugged in after the computer starts up. Therefore I cannot have the game controller and vm110 plugged in at the same time when the computer starts and the computer recognize the vm110.
    I am wanting to streamline my setup because I have a dedicated computer. I am trying to make it so when I turn on the unit everything is controlled by my wireless remote control with built in mouse without me having to plug and unplug a controller.
  2. egoexpress
    Hey phebbler,
    try this one: <a class=postlink-local href=http://www.x-simulator.de/forum/post12404.html#p12404 target=_blank>post12404.html#p12404</a>
    Btw, I've seen your simulator at youtube. Would be great if you would present it here :thbup:
    regards
    Christian
  3. phebbler
    phebbler New Member
    The virtual controller worked great. Thanks for the solution. I have recently moved and had to do a little modification on my simulator. Once I get every thing situated I will post it here.
    Thanks Again
