How can i use K8055 Vellermann for Gearshift Display?
Discussion in 'Force-Profiler Simulator Control' started by F12010, Oct 14, 2010.
  1. F12010
    F12010 New Member
    i want use a Vellerman K8055 USB Board, for use the Output to control a 7-Segment Display.
    i want use 3 Digital Output and a Logic IC SN 7447 (http://www.conrad.de/ce/de/product/170356/IC-SN7447-DIP
    for example:
    Output1------Output2-------Output3------7-Segment Display
    ---0--------------0--------------0----------------0
    ---0--------------0--------------1----------------1
    ---0--------------1--------------0----------------2
    ---0--------------1--------------1----------------3
    ---1--------------0--------------0----------------4
    ---1--------------0--------------1----------------5
    ---1--------------1--------------0----------------6
    ---1--------------1--------------1----------------7
    is this possible to make this in X-Sim Profiler?
    i do not understand the Output Setup in the Profiler Software :sos:
    Peter
  2. tomixtom
    tomixtom New Member
    Stuttgart - germany
    390Coins
    hi peter..
    i did actualy nearly the same thing - and it works perfect!
    i used not a 7 segment display - better use a 16 segment - sou can also display an N and R
    i wrote a small proggy for a pic 16fxx and used this as display driver /decoder..
    if you want me to, i can provide here the sourcecode or the final hex (and maybee a short description)
    so anyway.. i will start a new post next weekend - explaining all the scematics and also the setup of the force-profiler
    cheers tomixtom
  3. F12010
    F12010 New Member
    That sounds good. I am waiting for your answer in the post :yourock:
    best regards
    Peter
    PS: falls du deutsch kannst, verstehe ich es viiiel besser ;D
  4. mboRacing
    mboRacing Member Gold Contributor
    Automatiker
    Switzerland -Eiken
    - 151Coins
  5. tomixtom
    tomixtom New Member
    Stuttgart - germany
    390Coins
