Question How do I increase my FPS level?
Discussion in 'Forum and Website' started by Michael G. Hughes, Oct 7, 2022.
  1. Michael G. Hughes
    Michael G. Hughes New Member
    United States
    58Coins
    2DOF, 3DOF
    Hello Folks,
    I am new to this forum, i just want to ask about the fps level, I have tried many options such as Use Game Mode. defragment the hard drive, overclocking, updating bios and even though I checked my fps with the help of the FPS checker Still my fps is not increasing, So can anyone tell me what points should I consider to increase my fps level?
    Waiting for a positive response.
    148,094Coins
    +10,886 / 54 / -2
    If you can't squeeze any more from your hardware then you likely need to lower the game settings.
  3. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    37Coins
    your FPS is set from your equipment so on a TV is 60 or 75 hertz on my VR goggles its 45 hz per eye so the graphic card produces at 90 hz.
    to up graphic detail and OC your graphic card first ensure your air cooling is up to it you must monitor the heat produced and then up the super sampling in game or in steam VR per application in VR setting video
  4. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    The first thing you should have is a 144hz monitor, from there reduce graphics and see the results
  5. Dusan
    Dusan New Member
    Self emp., Programmer, Fullstack webdev, Linux adm
    Slovakia
    - 40Coins
    2DOF, 3DOF, Arduino
    Hi, can u send your computer hardware specs? and what games u playing.
    For example effective and simple way if u have NVIDIA GPU, u can set power management to performance mode, and render quality to high performance. For display resolution more than FullHD u can enable DLSS or AMD FSR, depends on your GPU ...
    Overclocking is very risky, dont do it i u not have any experience with that.
  6. Anthony Morris
    Multi trade
    Essex UK
    37Coins
    Why would you want to ?
