How to make a axis react only to + or - values
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by james wheeler, Jul 10, 2025.
Tags:
  1. james wheeler
    james wheeler Active Member
    - 22Coins
    What I am trying to accomplish is.
    In the tuning center the sway will go from a negative value to a positive value and I would like my Axis is only to react to one or the other.
    My rig is set up as a 2of using racingmat ultrasonic Arduino code and a moto monster driver. Axis 1 on the right and axis 2 on the left.
    When I turn to the right I get a + sway value and I would like that input only to be felt by Axis 1 essentially only pulling the left side down.
    Is there somewhere in the axis assignment tab where I can set a boundary for my motors to read the sways
    example axis 1 only will respond to values between positive 100% and -10% and vice versa for the axis 2. But only in the sway option.
    Thanks.
    151,455Coins
    +11,038 / 56 / -2
  3. james wheeler
    - 22Coins
    I suppose I should have mentioned I am using v1.2. But I'm glad you have helped guide me in the right direction. It's time to upgrade I have just been hesitant, worried about losing and having to reset up everything.
