How to setup a seat mover with 2 SCN5
Discussion in 'SimTools DIY Version' started by UweF, Nov 21, 2015.
  1. UweF
    UweF Member
    Softwareentwickler, Bastler
    Kolbermoor, Germany
    42Coins
    2DOF, SCN5
    Hi all,
    at the moment I have running my motion sim purely via Simcommander 4 and Simcommander 3. Now I would install and test the SimTools suite to compare some games in both versions of motion software and to play games with motion which are not supported in SimCommander respectively the better version of motion when the game is supported in both of the motion software.
    How can I get a step by step tutorial to configure Simtools suite to work with the SimXperience hardware
    alternately / besides to SimComander. I use the DIY-toolkit (2 SCN5 plus SX3000 power & control unit).
    Many thanks for your support.
    147,878Coins
    +10,880 / 54 / -2
  3. f1iceman
    847Coins
    as long as you have some compatable rs485 you should be fine and follow the link Noorbeast has sent you and double check every thing you do, one wroing move and you could cause alot of damage electrically.
    i might be able to help if you get stuck but nclabs is the better one for more info.
  4. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello, this question also applies to me... how setup a seat movements for my 3 dof motion simulator (2 SCN6 + 1 SCN6 for the rear loss of grip)?
