Hydraulic dof sim
Discussion in 'DIY Motion Simulator Projects' started by Flyjake22, Aug 19, 2023.
  1. Flyjake22
    Flyjake22 New Member
    26Coins
    Good morning from here in new zealand
    Im here to introduce myself self im jake im currently wanting to build a dof sim to go with my virpil helicopter controls
    Iv stumbled across an old kids helicopter ride its all hydraulic controlled before i hit go and go pick it up its only 150nzd i feel there would be valuable parts to use
    Engineering welding lathe work wiring im excellent at but computer integration is going to be my down fall am i biting off more then i can chew ?
    I would love to tap into the wealth of knowledge on here and see what you guys think
    Attached is a photo of the kids ride obviously im only thinking the bottom hydraulic system base part
    Regards jake
    148,565Coins
    +10,902 / 54 / -2
    Generally speaking these type of amusement rides tend to run proprietary stuff, so if you plan using the shell and changing out the actuators and hardware for something like servos then fine, but if you think you can control the existing hardware then likely not.
  3. Flyjake22
    26Coins
    Ah thanks i thought there may of just be a hydraulic pump and hydraulic cylinders i thought there may of been a way to control the flow Via controlling electric solenoids
    It would seem like it would have all the correct movements that id would need
    I understand the big professional commercial simulators are hydraulic am i way off the ball park here
    148,565Coins
    +10,902 / 54 / -2
    Years back @Thanos created a board to jailbreak some of these old amusement sims, but that has long since been discontinued.
  5. sci666
    sci666 Active Member Gold Contributor
    1,146Coins
    its an interesting idea, i think about something similar .... what if you put some ballscrew driven cylinders in it to pump the fluid into the actuators ? so you can control the ballsrew pump tubes like normal linear or rotary actuators .... ?!
