i need help with a simple solution
Discussion in 'DIY Motion Simulator Projects' started by gigi burchiani, Aug 24, 2015.
  1. gigi burchiani
    gigi burchiani New Member
    IT Specialist
    Montreal
    409Coins
    DC motor, Arduino
    Hi, community,
    this is my first post and i am a amateur sim racer looking for a simple solution
    what i want to achieve is a motion system that only will give me more feeling on car acceleration, braking point and gear change, and optionally some minor lateral g force
    i am on strict budget and my rig is build in wood i leave in apartment and i don't have a garage to start playing with metal, soldering is not an option
    watching videos in you tube my favourite motion system is the simexperience but i will be happy with something even more simple than that, something that move and shake in only one axes
    I purchase and Arduino mega and i am working in a data center so i have plenty of server power supply.
    I have some scrap old big hp printers so i can eventually recuperate some motors and parts
    please let me know if you can help me or reroute me to a current post with similar request
    thanks in advance
    Gigi
  2. gigi burchiani
    IT Specialist
    Montreal
    409Coins
    DC motor, Arduino
    I am adding more information to help:
    The sim rig is build entirely in wood mostly 2x4 that is very solid
    my racing seat is a nice and heavy Acura RSX 2002 racing seat installed on rails on top of the base made by 2x4
    I am using sim commander to drive several shakers , one is installed under the seat and 2 are installed inside the seat on both side where the airbags were located originally
    as soon i can post links i will add some pictures
    Thank you
    148,616Coins
    +10,909 / 54 / -2
    If there is a fair bit of weight to move then consider a shoulder mount design, as it has good leverage and there are plenty of member examples in the build threads: http://www.xsimulator.net/community/faq/shoulder-mount-rod-angles.149/
    You can get decent motors via Ebay in Canada: http://www.ebay.com/itm/GEAR-MOTOR-...384?pt=LH_DefaultDomain_0&hash=item51bd392f00
    Have a hunt through car scrap yards for an old tailshaft, so you can use the universal joint. Even in wood you can make a pyramid frame around the shaft and bolt through it to secure it firmly.
    It sounds like you could use the existing base, depending on its size, and make a top base for the seat, but it will be clearer when you post some pictures of it.
  4. pedrono2
    pedrono2 New Member
    czech
    213Coins
    3DOF, Arduino
    how much DOF will simulator have..??
    Engines from the printer will be weak :-/
  5. OlympusSim
    OlympusSim New Member
    Buenos Aires - Argentina
    608Coins
  6. bsft
    No soldering, no welding, no nothing!
    Buy a SimX kit
